Results 1 to 5 of 5
Thread: help required regarding baleno
    8888's Avatar
    Sep 2009
    249
    3 Post(s)
    Default help required regarding baleno
    hi pw's
    i hv a trouble with my baleno....i think its oil pump is expired....because when the car starts it gives very awkward noice like the pistons are running without oil.....nd i hv just checked that by opening the "tapa" nd found no oil....but i hv changed the oil a week ago......
    So i want any advice or help
    Can u plz tell me the best mechanic of baleno in lahore because changing oil pump is not an easy.....
    plz urgent help req
    8888's Avatar
    Sep 2009
    249
    3 Post(s)
    bump..
    us000's Avatar
    Aug 2006
    28
    1,519
    73 Post(s)
    first, get your engine seals checked, most probably oil is getting leaked from engne.
    warna ek week me oil kahin ni jata,
    jiyo aur jeenay do
    8888's Avatar
    Sep 2009
    249
    3 Post(s)
    bro ..gauge is showing that oil is full....the issue is that the oil is not reaching to the pistons or tapet..
    Skill's Avatar
    Aug 2009
    Select City
    7,885
    94 Post(s)
    40 Thread(s)
    Quote Originally Posted by 8888 View Post
    inside oil pump there are rubber seals which may wear with time and with contaminated oil.
    to check the oil pressure,some vehicles mostly diesel variants,come with oil pressure switch and oil pressure gauge.
    https://www.facebook.com/skillgrafik
