Results 1 to 5 of 5
Thread: clutch plates, presure plates
    MalikAdnanAli's Avatar
    Feb 2011
    Jhelum
    76
    Default clutch plates, presure plates
    hey friends
    sorry for bad english in advance,
    1 year back i changed my clutch plates and presure plates fc brand
    butt now my car giving voice of grrrrrrrrrrrrrrrrrrrrrrr with accelator but when i race up, its fine and smooth
    my mechanic said that previous mechanic who changed both plates, didnt apply tool on flywheel,
    dis effected on plates? if yes then please tell me fc is better or my friend told me that taiwan's plates are good and cheap in price,
    please suggest me for which i should go, FC or taiwan clutch plates
    regards
    Feb 2011
    Jhelum
    76
    no one?
    supraman2jz's Avatar
    Jun 2008
    33
    2,697
    76 Post(s)
    I had the clutch plates of my car changed recently. Because I had prolonged the replacing of the clutch, the flywheel needed machining (as was told to me by my mechanic). He sent it to lathe machinist (kharadia) and it came back smooth and leveled. Maybe that's your problem. Take it to another mechanic and see what he suggests. If the clutch plates are new, they probably would work fine regardless of the brand.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    either the flywheel was worn down or scratched (not likely) or you did not "wear in" the clutch properly before general use.
    You have to bed in the clutch too like you do with brakes, otherwise the plate glazes and hardens causing chatter and vibration on release. It is done by slowly releasing the clutch in first gear stopping and doing it again for about 15 mins, after that it is recommended to lightly drive the car with very low accelerator load for about a week, after that you can drive normally.
    I had a young "brat" customer who had toasted his RX8 clutch plate twice in a month, when he came to me, I replaced the plate with a ceramic composite plate and wore in the clutch myself for 2 weeks before handing over the car, the car never had any issues after that.
    punk1's Avatar
    Nov 2005
    Peshawar
    28
    2,090
    25 Post(s)
    5 Thread(s)
    I have slightly used FC clutch and pressure plate for sale
    let me knw if anybody wants it
    03339148844
    clutch plates presure plates -400806 clutch plates presure plates -400807 clutch plates presure plates -400808 clutch plates presure plates -400809
