Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Like Tree3Likes
Thread: A/T car in budget of 6..?
    Khamosh's Avatar
    Jul 2012
    258
    4 Post(s)
    Default A/T car in budget of 6..?
    Please suggest an A/T car for a beginner.. In the mentioned budget.. Also I am not looking at JDMz bcuz of expensive spare parts and 660cc engine..
  2. #21
    Khamosh's Avatar
    Jul 2012
    258
    4 Post(s)
    A/T Car owners.. please give feedback about ur cars..
  3. #22
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by bradpit View Post
    bro never buy a coure with auto it will fail or leak oil factory problem in PKDM coure u can also search PW forums to verify.
    Alto 2007 is good but no parts available so go for vitz if u want JDM.
    I like civic much because there are plenty of parts from pakistani china thailand and in junkyard too and their auto is very reliable.
    The cuore autobox has only one big problem which is the reverse piston sticking (because its plastic), It requires a BRAND NEW PISTON to be installed to rectify this fault, if you install a used piston - it will fail shortly. The other problem is the speed governor getting stuck or the plastic gear driving it gets broken off - this causes the transmission to forever stay in 1st gear. I have never encountered a fluid leak problem that could not be corrected.
    The problem is overheated ATF and not changing it on time. Of all the A/T cars I have come across in Karachi nearly all never had a fluid change because their mechanics were against (gear aail chenge) - I have even seen a transmission using kerosene mixed in manual gear oil - because the swap guys in quetta did not have a gallon of ATF at hand.
  4. #23
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    some people had oil leakage problem but it is not with every cuore. it has light steering, good suspension, reliable, responsive and comfortable. on petrol average is 11-14 on AC, so bit low. parts are expensive but of good quality. quality of JDM's is better than local cuore but parts are found in junkyards later.
  5. #24
    TheGreatOneAK316's Avatar
    Mar 2012
    New York City
    20
    864
    6 Post(s)
    1999-03 Toyota Vitz.
    The man with an insane brain, powered by a 750hp V12 engine.
  6. #25
    Khamosh's Avatar
    Jul 2012
    258
    4 Post(s)
    Need more reviews on Cuore vs JDM..
