Results 1 to 6 of 6
Like Tree1Likes
  • 2 Post By Xulfiqar
Thread: opinion regarding W124
    doc.tarzan's Avatar
    Dec 2009
    Mardan
    34
    2,550
    47 Post(s)
    4 Thread(s)
    Default opinion regarding W124
    A.A ... Eid mubarik to everyone.As the topic says i need opinions/advice regarding buying a w124.I am planing to buy a later version 94/95.Kindly guide me regarding reliability, availability/price of parts and what should be approximate price for a clean 94/95 one (preferably the one with the biggest engine)
    doc.tarzan's Avatar
    Dec 2009
    Mardan
    34
    2,550
    47 Post(s)
    4 Thread(s)
    Marschall's Avatar
    Aug 2009
    Chowha saidan shah
    31
    1,145
    24 Post(s)
    Sir check the one in classified section 300e 4matic i think.......btw this car is a panzer tank KRUPP STEEL
    "Stand by your glasses steady and drink to your comrade's eyes.
    Here's a toast to the dead already and hurrah for the next to die."
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    4matic repair will make you and the mechanic wince with pain. The later models look nice with their body kit and headlamps and sit lower too, Their dashboard is also slightly different (more wood). But they are heavily padded everywhere to insulate from noise.
    The problems with the late W124 were bad wiring insulation that breaks down after 10 years or so (the engine room one) - the rest remains good. Some A/C cars had bad evaporators from the factory that leak (replacing them requires removal of the entire dashboard, the wiper etc.. Its not as easy as a corolla.
    Otherwise the car is good - but bear in mind that at this age you will want to check all rubber parts under the car (any model W124), Its got a lot of bushes in the rear, 5 links a side (10 bushes), one bearing bush each side, 4 sudframe bushes, 3 differntial bushes. When all are in good condition the car works like it should (firm yet supple ride), if they are bad - it would ride like a bad maintained mehran.
    The front is pretty simple, but only get it aligned by someone who has the additional tools required to align this car. Its not just simple tow adjustment, in this car, caster, camber and toe are adjustable. - The steering box needs to be locked first then a road force simulating bar installed between the front wheels. Then the technician should follow the exact chassis spec alignment, e.g. E200 and E420 have different alignment.
    doc.tarzan's Avatar
    Dec 2009
    Mardan
    34
    2,550
    47 Post(s)
    4 Thread(s)
    Thanks marschall. Thanks xulfiqar for such a detailed and informative reply, i had a 95 280e in sight ... Thanks
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    95 280E - it should be having the M104 CIS engine... nice car, minimum engine electrics. Get the full vin so we can see what transmission it uses and what features it carries
