Results 1 to 1 of 1
Thread: RPM problem in swapped Speedo Meter.
    khattak_lala's Avatar
    Jul 2009
    Rawalpindi
    26
    188
    4 Post(s)
    Default RPM problem in swapped Speedo Meter.
    Salam, i recently put in a Speedo Meter in my 88 Corolla , it is what they call a CAMRY meter. Everything else is functioning correctly EXCEPT the RPM meter. Its readings are wrong. The engine i have is a 5E, which is an EFI engine . Example the rev meter shows 4000 when the engine is locking . and on idle it shows 200 . Has anybody faced this problem.? And if yes then how do i get it repaired and by whom.? I live in Rawalpindi. Regards.
    Burn Rubber Not Ur Soul.!
