Results 1 to 6 of 6
Like Tree3Likes
  • 3 Post By v8
Thread: D15B VTEC vs R18, how does D15B wins? with less torque and less BHP?
    maaz70's Avatar
    Oct 2012
    51
    Default D15B VTEC vs R18, how does D15B wins? with less torque and less BHP?
    assalam o alaikum n below are the specifications for both of these engines ..
    D15B 3-Stage VTEC
    Bore and Stroke :75,0?84,5 mm
    Displacement : 1,493 cc (91.1 cu in)
    Rod Length : 137 mm
    Rod/Stroke : 1.62
    Compression : 9.3:1
    Power : 130 PS (96 kW; 128 hp) at 7,000 rpm[6]
    Torque: 139 Nm at 5,300 rpm
    VTEC 12-valve to 16-valve switch over : 3,000 rpm (below such engine speed, the engine is operating in 12-valve mode)[7]
    VTEC high cam switch over : 6,000 rpm
    Redline : 7,200 rpm
    Valvetrain : SOHC, four valves per cylinder
    Connecting rod length : 137 mm
    Connecting rod big end diameter : 48 mm
    Fuel Control : OBD2a
    Head Code : P2J-07
    ECU Code: P2J (small case ECU)***
    R18A1
    Displacement: 1,799 cc (109.8 cu in)
    Compression: 10.5:1
    Bore & stroke: 81.0 mm ? 87.3 mm (3.19 in ? 3.44 in)
    Power: 140 PS (103 kW; 138 bhp) @ 6300 rpm (Japanese Spec)
    Torque: 17.7 kgf?m (174 N?m (128 ft?lbf)) @ 4,300 rpm
    VTEC for economy 1,500-3,000 rpm
    As you can clearly see from the stats above that R18 should be more fuel efficient and more powerful then D15B VTEC but I have heard and also experienced that D15B VTEC can easily beat R18 and its also more fuel efficient? any senior members on it that why it happens? and do you also experience the same?
    v8
    v8 is offline
    v8's Avatar
    Mar 2009
    Dubai
    34
    4,720
    12 Post(s)
    4 Thread(s)
    As per my experiennce, no.
    Stock d15b cannot take lead from r18. Yes, I've seen d15b with chipped ecu and stage1 mods easily smoking r18.
    It would also depend which car you're running on d15b. Charade with stock d15b will give tough time to 8th gen civic r18. Same d15b in 5th/6th gen civic, then r18 8th gen will lead. (assuming equal launch and shifting skills of both drivers)
    I even lost with 1.8 altis on my stock d15b (roll-on)
    maaz70's Avatar
    Oct 2012
    51
    hmm ok and please also share your experiences regarding fuel consumption as per the stats the R18 should be more economical but again in my experience D15B VTEC is more economical .. so also share your experience and opinion about fuel efficiency too along with the power and speed ..
    v8
    v8 is offline
    v8's Avatar
    Mar 2009
    Dubai
    34
    4,720
    12 Post(s)
    4 Thread(s)
    d15b is more fuel efficient, infact it's famous for it specially the one you're taking about: d15b dual vtec (3stage)
    maaz70's Avatar
    Oct 2012
    51
    hmm and what do you think is the reason for it? as you can see R18 has less RPM for its maximum power and torque so technically R18 should be more fuel efficient also they both are 3 stage VTEC so why then D15b is more fuel efficient?
    v8
    v8 is offline
    v8's Avatar
    Mar 2009
    Dubai
    34
    4,720
    12 Post(s)
    4 Thread(s)
    d15b 3stage works on only 12valves under 3k rpm
    r18 also has economy mode till 3500 rpm efficiently managed through i-vtec, yet it is not switching off valves like d15b 3stage but partially closing and reducing the fuel intake according to throttle response.
    and 1.8L displacement would need more fuel to burn as compared to 1.5 (81x87mm vs 71x84mm b/s)
