Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By portage1
Thread: Radiator Drain bolt problem
    prince101's Avatar
    Dec 2011
    134
    Default Radiator Drain bolt problem
    The drain bolt at the bottom of the radiator have very minor leakage ,I change this bolt few days back because the previous one have some crack in it but this one also leaks but the bolt is not cracked the bolt is fully tight if I tight more then it must be crack . The leakage is very minor so the problem is not the reduction of the coolant but the system takes air from this point , you can see in the pic that blue color coolant on the bolt , is their any solution for this problem ??
    Radiator Drain bolt problem -1103281
    lahori's Avatar
    Apr 2005
    36
    1,013
    26 Post(s)
    use magic depoxi to cover the leakage
    If travelling was free, You'd never see me again.
    john0995's Avatar
    Jun 2008
    Hari pur
    1,532
    17 Post(s)
    chk the seal of drain bolt
    CoMmiNg SoOoOoOoOoOoOoOoOn
    ToxicDevil's Avatar
    Nov 2010
    1,317
    15 Post(s)
    13
    use teflon tape?? or silicone.
    ToxicDevil's Avatar
    Nov 2010
    1,317
    15 Post(s)
    13
    check the O-ring
    prince101's Avatar
    Dec 2011
    134
    i check the O ring it is ok
    suzukialtomehran's Avatar
    May 2005
    Sargodha
    26
    7,286
    16 Post(s)
    just cut a old cycle tube and make a o ring problem solved.
    Two of the best quotes of Punjabi : 1. Rull tan gae aan! Per Chass aa Gae ai!, 2. Gal Pya Dhol Ty Wajana Penda ay.
    prince101's Avatar
    Dec 2011
    134
    Quote Originally Posted by suzukialtomehran View Post
    how to make O ring from a cycle tube ??
    portage1's Avatar
    Nov 2005
    hyderabad & Michigan
    10
    21,004
    37 Post(s)
    3 Thread(s)
    Its call " Drain Plug " not bolt
    I'm a freak who lost his mind in the busy world of today and takes his frustration by being funny with others
    riz_'s Avatar
    Sep 2007
    Select City
    50
    6,175
    8 Post(s)
    It is quite possible that the threads on the plug are not quite "snug" inside the drain. If you have Teflon tape available, wrap it around the threads a few times. If you don't have access to it, you can use high temperature silicone sealant on the threads. Just don't overdo it. Use as little as needed. Teflon tape is much better option though. You should be able to find it easily at plumbing supply stores.
    Do not use any glues or epoxies.
    My opinions, suggestions and thoughts are strictly my own. I reserve the right to be human and make mistakes.
    prince101's Avatar
    Dec 2011
    134
    Quote Originally Posted by riz_ View Post
    I have a teflon tape .i try it ... thanx
  12. #12
    prince101's Avatar
    Dec 2011
    134
    Quote Originally Posted by portage1 View Post
    ok thanx for correction but where is the solution ?? or you are here for only make corrections ??
