Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By zunny
Thread: Abs and Airbags warning lights in Nissan PINO 2009
    altisdualvvti's Avatar
    May 2012
    21
    1,966
    42 Post(s)
    Default Abs and Airbags warning lights in Nissan PINO 2009
    My cousin has got a nissan pino 2009.
    mileage 9500+(maybe reversed)
    Display panel is displaying abs and airbags warning lights but Abs is working properly and i dont know about airbags.How can he fix this issue.
    May 2012
    21
    1,966
    42 Post(s)
    anyone?
    zunny's Avatar
    Mar 2008
    Other
    37
    4,107
    5
    29 Post(s)
    2 Thread(s)
    obd2 diagnostics will give you the fault code.with the same tool erase the error cose and would turn off the warning lights.if it doesn't then it could either be an accident repaired car with sone parts missing.hope its just a code error as usually when a system develops a fault and its repaired you need to erase the error worh this OBD tool.if after removig the code the light comes on again then u have a system fault
    'RESPECT',DIY projects: 1) 'CRUISEMATEC' 1st PKDM 8th Gen Civic with OEM Honda CRUISE CONTROL 2)Steering Audio Controls 3)AUX for OEM 8th Gen 6 CD CHANGER 4)Leather RED H logo!
