Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By memad
Thread: Tiptronic help needed
    puredesi's Avatar
    Jul 2009
    Sialkot
    25
    309
    2 Post(s)
    Default Tiptronic help needed
    Salam to all . I want to ask members about a simple question . in tiptronic transmission the + or - does is give you an easy to use manual control. So if you are in D and you want to shift to a lower gear than what it's in, tap the lever to the left (the - side) and it will drop from 5th to 4th or whatever. Tap it to left again and it will go down another gear, tap it to the right to go back up. But do i have to press the clutch while doing all this? Do i have to press the clutch while shifting from normal D mode in an automatic to the manual tiptroni system ? Regards
    puredesi's Avatar
    Jul 2009
    Sialkot
    25
    309
    2 Post(s)
    Any one ?
    afnanSJfayaz's Avatar
    Nov 2010
    Newcastle upon Tyne
    1,164
    13 Post(s)
    There is no clutch in an automatic/Triptronic transmission so, no.
    hassan.ellahi's Avatar
    Dec 2010
    1,164
    20 Post(s)
    2 Thread(s)
    Bro I am no expert but I don't think so that triptronic cars have clutch pedal! Maybe you are mixing pedal shifters with triptronic gears! You don't have to press any clutch I think because it doesn't exist
    memad's Avatar
    Nov 2010
    39
    5,497
    179 Post(s)
    If there is no clutch then you can ask any car passing by to engage clutch while you shift up or down in your tiptronic
    puredesi's Avatar
    Jul 2009
    Sialkot
    25
    309
    2 Post(s)
    By pedal i mean the break we use to initiate the gears . I mean that while driving in normal auto mode we just have to pull the lever into triptronic mode or first slow the car press the brake and then put it in the triptronic mode @memad @hsn18
    Dec 2010
    1,164
    20 Post(s)
    2 Thread(s)
    Quote Originally Posted by puredesi View Post
    no need to press the brake bro! just pull the lever into triptronic mode, shift down and enjoy
    arhum1994's Avatar
    Jun 2009
    22
    433
    16 Post(s)
    In triptronic transmission there is no clutch, you just change gears by the paddle shifts on the steering or as you said by the gear lever. Dont know how it happens, only experts can answer that.
    These type of transmission are known as a semi-automatic transmission.
    puredesi's Avatar
    Jul 2009
    Sialkot
    25
    309
    2 Post(s)
    Where are the experts then ???
    memad's Avatar
    Nov 2010
    39
    5,497
    179 Post(s)
    Test driving with Tiptronics
