Results 1 to 5 of 5
Thread: Which Spark Plugs for 2000 Model JDM ALTO VXR 660cc Automatic???
    qazishehryar's Avatar
    Sep 2013
    55
    Default Which Spark Plugs for 2000 Model JDM ALTO VXR 660cc Automatic???
    Salam Guys,
    As the title says, stock spark plugs are worn out and my mechanic recommends to replace them. I have seen many threads here where people recommend Iridium or Platinum spark plugs. So which brand and model of Iridium or Platinum spark plug will suit the engine of my 2000 Model JDM ALTO VXR 660cc Automatic. Also should i change the cables too with spark plugs???? Need experts help here ...
    Also, to increase the cars performance which stuff should i install in it?????
    Thanks in advance you guys rock
    Ishtiaq778's Avatar
    Feb 2010
    Dina
    1,172
    81 Post(s)
    NGK 5691 BCPR7EIX-11 Single Iridium Spark Plug
    NGK's IX Iridium Series Plugs were Designed Specifically for the Performance Enthusiast.
    • Fine Wire Center Electrode Ensures High Durability and a Consistently Stable Spark
    • Iridium Alloy has an Extremely High Melting Point, Perfect for Today's High-Tech, High Performance Engines
    • Trivalent Metal Plating Provides Superior Anti-Corrosion and Anti-Seizing Properties
    • Corrugated Ribs Prevent Flashover
    • Pure Alumina Silicate Ceramic Insulator, Provides Superior Strength and Better Heat Transfer
    • Copper Core Aids in Heat Removal
    • Triple Seals Prevent Leakage
    Ishtiaq778's Avatar
    Feb 2010
    Dina
    1,172
    81 Post(s)
    G-Power?
    Improved Fuel Efficiency, Lower Emissions, Quicker Starts.
    • Fine platinum tip reduces required voltage
    • Extremely durable under high heat
    • Trivalent Metal Plating - superior anti-corrosion and anti-seizing properties
    • Faster starts and quicker acceleration
    • Better fuel economy and lower emissions
    • Best platinum spark plug at an economical cost
    Which Spark Plugs for 2000 Model JDM ALTO VXR 660cc Automatic??? - Gpower details
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    No need to change cables
    Sent from my HTC Sensation 4G with Beats Audio using PW Forums mobile app
    Sep 2013
    55
    Quote Originally Posted by Ishtiaq778 View Post
    G-Power?
    Where can i get these GPOWER plugs???? and whats the price???? thanks ....... ALSO which one is better between these two NGK 5691 BCPR7EIX-11 or NGK G-POWER
