Results 1 to 6 of 6
Thread: Please give your opinion on Alto VXR 660 Automatic 2004 Registered 2007 @Rs. 530,000
    kashif2day's Avatar
    Mar 2009
    36
    6
    Question Please give your opinion on Alto VXR 660 Automatic 2004 Registered 2007 @Rs. 530,000
    Hi friends
    Please Give You suggestion shall I go for buy or advise anyother option? I need automatic my range 100Kto 500K
    Pros:
    A) 1st owner
    B) Engine OK as per mechanic
    C) New Tyre/ Battery
    D) CNG /Petrol / A.C
    Cons:
    A) Engine checklight ON (u can see in pic. 1380742288_551995092_11-..)
    B) Little sound from gear box in D or 2
    C) Sometimes comes from CNG to Petrol byself.
    Fahad.Ayub's Avatar
    Aug 2013
    21
    1,959
    32 Post(s)
    the car looks alright but do negotiate on the price using the check-light and faulty gearbox
    How does the car drive ? is it smooth or drives hard ? and please get the car thoroughly checked from a good mechanic because most of these Alto's have engine problems
    If i were you i would buy a Toyota Duet because it has a 1000c engine and runs good on cng
    kashif2day's Avatar
    Mar 2009
    36
    6
    car drive smooth, no big sound on rockky roads, i also hv dueet in my mind..but couldn"t find ..anyway thnx
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    go for it as parts wont be an issue for u u can get whole engine assembly with gear in 35k
    only issue in this car are brakes as brake grip is 60 percent on CNG its better to remove CNG as it give 14-15 km per litre easily
    kashif2day's Avatar
    Mar 2009
    36
    6
    thanx in suzukis, agree ..parts &maintenance cost low as compare to toyota
    bradpit's Avatar
    Nov 2010
    42
    2,064
    87 Post(s)
    2 Thread(s)
    Quote Originally Posted by kashif2day View Post
    Hi friends
    Pros:
    A) 1st owner
    Cons:
    Bhai you can get a clean local Alto 2008 with less than 75,000 Km for 5.5 lacs.
    This car does not worth more than 4.5 lacs.
    All life is an experiment. The more experiments you make the better.
