Results 1 to 11 of 11
Thread: help regarding toyota corolla 2.0d which part is this?
    rustedsoul's Avatar
    Oct 2013
    Rawalpindi
    32
    2 Post(s)
    Default help regarding toyota corolla 2.0d which part is this?
    hey im looking to buy a toyota corolla 2.0d 2003
    one of the car has a different looking part can experts tell me which part it is and y its changed?
    help regarding toyota corolla 20d which part is this? -1298594help regarding toyota corolla 20d which part is this? -1298595
    sheikh_wah's Avatar
    Nov 2005
    42
    579
    9 Post(s)
    this part is replacing treditional Air Filter box. I don't know why.
    MarX's Avatar
    Oct 2007
    35
    508
    6 Post(s)
    @OP
    Sir ,the part changed is AIR Filter Housing containing Air filter
    Looks like somebody tried to change the kind of air filter
    which we normally put in Corolla.The reason can be
    1. He tried to alter the airflow.
    2. He tried to save money by putting in cheap filters.
    3. He might be a mechanic from the most left and upper part of pakistan
    rustedsoul's Avatar
    Oct 2013
    Rawalpindi
    32
    2 Post(s)
    Ok thanks soo much the one in the first pic is replaced because all the rest of the cars have the one insecond picture and the first car is 2002 i think toyota might have changed it in the next year model
    supraman2jz's Avatar
    Jun 2008
    33
    2,700
    76 Post(s)
    Looks like a swapped engine. Why would someone fondle with the air cleaner box otherwise.
    Sent from my JY-G2 using PW Forums mobile app
    "Being between arabs, you call it "Jimmss Yukaan Sagheer", or GMC yukon." - Xulfiqar.
    Owais_Yunus's Avatar
    Sep 2005
    28
    2,224
    60 Post(s)
    The car could've had the engine replaced or some major work dont to it and in the process, the air cleaner probably got lost / stolen and the owner / mechanic replaced it with the cheaper solution. I think that is the type of the air cleaner that uses oil instead of a filter element.
    Since that raises suspicion, I'd recommend you to tally the engine number with that written on the registration book and take a trusted mechanic with you.
    rustedsoul's Avatar
    Oct 2013
    Rawalpindi
    32
    2 Post(s)
    i found out its the airfilter which is filled with oil
    Teeboyuk's Avatar
    Sep 2012
    Other
    1,608
    8 Post(s)
    This is only a guess. I know they change air filter boxes on Toyota vans to larger ones of tractors to stop dust getting into the engine..it looks very similar..
    Pakistan.. Toyota hilux..golf mk2 gtd..rolla 2.0d..nissian sunny.. Yamaha pw 50.. Coventry uk....audi v8 d11..golf mk2 rallye..honda crx..evo 8..golf mk2 gtd..Vauxhall insignia..
    Teeboyuk's Avatar
    Sep 2012
    Other
    1,608
    8 Post(s)
    If it's filled with oil there's something wrong..
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    Quote Originally Posted by Teeboyuk View Post
    These type of filters are soaked with oil.
    Teeboyuk's Avatar
    Sep 2012
    Other
    1,608
    8 Post(s)
    Filled with oil. Sprayed with oil...?
