Results 1 to 16 of 16
Like Tree2Likes
  • 1 Post By Marwanpasha
  • 1 Post By fawwad
Thread: after applyng brakes its urgent
    fawwad's Avatar
    Mar 2005
    26
    519
    Default after applyng brakes its urgent
    friends whn i apply,brakes in honda accord only driven 48000,whn i apply brakes,it gve "chuu" awaz wht does it awaz is abut any idea plzzzz
    Every second of Every minute is important in pakwheels
    drtanveerali's Avatar
    Apr 2009
    Select City
    40
    1,305
    7 Post(s)
    Check your brake pads for worn out.
    www.dr-tanveer.com
    Marwanpasha's Avatar
    Oct 2012
    22
    2,088
    71 Post(s)
    4 Thread(s)
    Could be brake pad. Make them checked as soon as possible or it will destroy your disc too.
    Sent from my iPhone using PW Forums mobile app
    Yahoo i got the app at last...!
    dosimeter's Avatar
    Apr 2011
    380
    4 Post(s)
    if the brakepads wear out, the metal touches the disk and destroys it. get it checked.
    fawwad's Avatar
    Mar 2005
    26
    519
    @Marwanpasha and dosimeter thnx bro.... any idea how much brake pads costs of accord 2003?
    Oct 2012
    22
    2,088
    71 Post(s)
    4 Thread(s)
    Quote Originally Posted by fawwad View Post
    No idea about it. I guess it should be around 8-10k per pair from Honda.
    dosimeter's Avatar
    Apr 2011
    380
    4 Post(s)
    don't have an idea about price, but be careful about what you choose, there maybe some low quality brands for a lower price, don't go for them. try to find original or atleast japanese ones.
    onlyfaith's Avatar
    Sep 2010
    5,934
    8 Post(s)
    yea bad brake pads
    top documentaries " Tears of Gaza"
    Aftab13's Avatar
    Aug 2009
    Select City
    26
    103
    I guess, it's brake booster needs replacement..
    JDM
    bradpit's Avatar
    Nov 2010
    42
    2,064
    87 Post(s)
    2 Thread(s)
    Brother first check from Mechanic or suspension guy that brake pads and disc are in shape or not.
    Is your brake pedal play normal or it goes to the floor ?
    Brake fluid level, last changed date ?
    2003 Accord Nissin brake pads front 11,300 rear 7,900.
    MK brake pads front 8,000 rear 4,200.
    Importer's rate only almighty Allah knows what 3S dealer will charge you.
    Also use genuine Honda heavy Duty DOT3 brake fluid in read & white bottle do not poor good old sikken.
    Let me know if you cant find them.
    All life is an experiment. The more experiments you make the better.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    get some copper antisieze and apply to the back of the pads, do not let the mechanic apply his old grease on them.
    If the pads are worn down then replace as necessary
  12. #12
    zaeem9236's Avatar
    Apr 2012
    124
    3 Post(s)
    done.....
  13. #13
    fawwad's Avatar
    Mar 2005
    26
    519
    Default thanku to all
    thnx brothers for helping em out.
  14. #14
    fawwad's Avatar
    Mar 2005
    26
    519
    Default @bro
    Quote Originally Posted by bradpit View Post
    bro brakes are normal....
  15. #15
    mianaasim's Avatar
    Nov 2013
    264
    2 Post(s)
    wat is the price of MK for GLi 2010?? from importer as many fakes available in market.
  16. #16
    bradpit's Avatar
    Nov 2010
    42
    2,064
    87 Post(s)
    2 Thread(s)
    Quote Originally Posted by mianaasim View Post
    Better to buy Toyota OEM Thailand pads from Toyota 3S or 2S they will charge Rs. 1,000 extra but you will be sure that they will NEVER give fake goods. At least not here.
