Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Like Tree2Likes
Thread: suggestion required for best rim and tyre size
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Default suggestion required for best rim and tyre size
    Note : its a family car so there should be no problem road clearance or hitting the arc
    Plz let me know rims style tyre size which will suit my car
    Sent from my GT-I9105 using PW Forums mobile app
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Some pics
    hsumbal1's Avatar
    Feb 2008
    41
    1,427
    5
    39 Post(s)
    The Tire size is mentioned on the door sil on the left side door.
    Stick to the original size. if you go for a bigger rim make sure that you use the tire size converter and make sure that the diameter stays the same
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    I m currently using 14 " 185/65 wanna upgrade
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Quote Originally Posted by asad1 View Post
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    15" or 16"
    bradpit's Avatar
    Nov 2010
    42
    2,064
    87 Post(s)
    2 Thread(s)
    15" or 16"
    MashAllah nice car. E-AE110 1.5LX with 5A-FE 100 PS and 4 speed auto.
    Stock size 175/70 R13.
    I would recommend a 185/60 R14 on Yoko C Drive 2.
    16 inch wheels and rims are damn expensive more expensive are the Japanese KYB front shocks which you may need to replace by using oversize tyres.
    185/55 R15 is also good balance between performance and practical damping.
    The only acceptable size in 16' is 195/50 R16 which is 1.1 inch larger and 4.6% bigger than stock.
    All life is an experiment. The more experiments you make the better.
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    JazakAllah! Btw its an eighth generation corolla SE Saloon limited own it since it is registered in Pakistan
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Bumppp
    bilalahm's Avatar
    Jan 2004
    3,045
    23 Post(s)
    7 Thread(s)
    14 " 185/70 would do the job without ruining the fuel average, would give better road clearance and more cushion for bumps.
    Apart from pakwheels, my blogs can be also be viewed at http://tajziat.blogspot.com/
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    I want to upgrade
  12. #12
    bilalahm's Avatar
    Jan 2004
    3,045
    23 Post(s)
    7 Thread(s)
    This was a "suggestion for the best rim and tire" keeping in mind "Note : its a family car so there should be no problem road clearance or hitting the arc". The "upgrade " to a rim of increased diameter would need compensation in the profile of the tire which if decreased would make the ride uncomfortable and the suspension to wear out much sooner unless the springs area also changed in order to keep the profile same.
  13. #13
    bradpit's Avatar
    Nov 2010
    42
    2,064
    87 Post(s)
    2 Thread(s)
    I want to upgrade
    Brother the real question is that you want to upgrade for 'comfort / fuel economy' or 'sportiness/handling' ?
  14. #14
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    comfort n look as well
  15. #15
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Bummmpppp
  16. #16
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Bump
  17. #17
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Is it looking good
  18. #18
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    These are current rims
  19. #19
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Have a choice of this as well
  20. #20
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Bump
