Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Like Tree9Likes
Thread: Parking shade for my car
    husnainkhan's Avatar
    Nov 2007
    83
    1,359
    20 Post(s)
    Default Parking shade for my car
    Salam guys. I had made an proper parking shade at my house long time back on order for my car. It is basically green Net based on metal structure. Now the problem is that since thin ordinary green net is not waterproof so im facing issues because whenever i get my car cleaned the wild cats would come, sit and rest on the green shade and usually pee on the green net which drops like a tap on my car which is parked right under the shade. So someone suggested me to get the fiber shade made on order so i went to inspect the estimated cost and the fiber sheets are for 120 rs/square feet. Which is getting too expensive for me. Please someone suggest me a bit cheaper and total waterproof solution so that apart from cat pee my car can get protection from rains aswell. Thanks in advance.
    fazalwahab11375's Avatar
    Jan 2012
    Select City
    29,483
    36
    842 Post(s)
    23 Thread(s)
    A waterproof shade called as "TARPAAL" in local language is available in market. get it fixed on the exiting frame you have.
    Pakwheels on the MAP; http://bit.ly/ZVyXcZ
    nfsmostwanted's Avatar
    Mar 2010
    22
    3,242
    118 Post(s)
    Why not use the local plastic sheet people use for house lenters i guess. that should serve the purpose .
    Nov 2007
    83
    1,359
    20 Post(s)
    Quote Originally Posted by fazalwahab11375 View Post
    Is it totally waterproof?? bec my main motive is to prevent even a single drop of water and to prevent cat pee to fall on the car
    Respect and care about your car rather than abusing it on the streets.
    Nov 2007
    83
    1,359
    20 Post(s)
    Quote Originally Posted by nfsmostwanted View Post
    Bro can you tell me if its waterproof? and from where can i get it in Karachi any idea?
    Mar 2010
    22
    3,242
    118 Post(s)
    Quote Originally Posted by husnainkhan View Post
    Yes bro its totally water proof. as i'm in lahore ,i'm having no idea of KARACHI market.. u can get it from any good hardware store
    Ishtiaq778's Avatar
    Feb 2010
    Dina
    1,172
    81 Post(s)
    Parking shade for my car - images?qtbnANd9GcTgtAgkKijh0w5bru3UvTQodjowaKAmHXCeFsqr28TEt1dNok2J
    Dear, i am using shade of this Jasti Sheet......its rust proof ,leak proof and excellent life.......i m using it from last 6 years....
    Go to Trunk market.....and get estimate......or tell me the exact size of your metallic structure......i ll give u estimate after asking from the trunk market
    Imtiazmughal's Avatar
    Nov 2012
    al-Jubayl
    37
    956
    13 Post(s)
    plastic sheet is water proof, but that is only for inside use. if anyone use outside, that will damage in 2-3months. so better to sue TERPAAL that is also waterproof.
    ToxicDevil's Avatar
    Nov 2010
    1,317
    15 Post(s)
    13
    Tarpaal is like a thick piece of cloth. It wont be so easy to clean.
    I would suggest the green fiber glass or a steel sheet as mentioned above. They both are solid and strong and easy to clean.
    omar_575's Avatar
    Nov 2005
    28
    1,731
    40 Post(s)
    tarpaal doesn't last very long.. these days people are using fiberglass, it's a bit expensive but it lasts longer and looks better since it's more rigid and maintains it's shape.
    the problem with metallic sheets that they create a racket during rain or even when a cat jumps on it. tarpaal starts sagging after some time and rain water collects in it, eventually it tears apart. have a look at this link : (Fiberglass roofing sheets linning THERMOLIGHT(since 1985) - Lahore - Everything Else) .. PS: i've no relation to this company and i'm just giving you an idea of different designs. I'm in no way recommending this to anyone.
    Nov 2007
    83
    1,359
    20 Post(s)
    Guys, Would penaflex sheet be a better idea? I want a cheaper solution for now.
  12. #12
    Nov 2012
    al-Jubayl
    37
    956
    13 Post(s)
    that can also a good idea.
  13. #13
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by Ishtiaq778 View Post
    I built a shade like that in my house in karachi, I had two gates, one was a proper covered, one and one was open, I fit two long lamps under it.
  14. #14
    Nov 2007
    83
    1,359
    20 Post(s)
    Zulfiqar bhai will "penaflex sheet" be of any use?
  15. #15
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    yep as a ghetto rig solution
  16. #16
    suzukialtomehran's Avatar
    May 2005
    Sargodha
    26
    7,286
    16 Post(s)
    i got like this and its a pain in the a** in rainy season.
    Two of the best quotes of Punjabi : 1. Rull tan gae aan! Per Chass aa Gae ai!, 2. Gal Pya Dhol Ty Wajana Penda ay.
  17. #17
    awais.9's Avatar
    Mar 2010
    69
    11,927
    5
    162 Post(s)
    15 Thread(s)
    how much does it costs btw to build a parking shade for one car?
  18. #18
    Nov 2007
    83
    1,359
    20 Post(s)
    Quote Originally Posted by chaudhary9 View Post
    Fiber glass one here in Karachi is 120/square feet and 150/square feet with labour fitting. Which gets a bit costy for even one sedan.
  19. #19
    Nov 2007
    83
    1,359
    20 Post(s)
    Quote Originally Posted by suzukialtomehran View Post
    Is that because of sound when the drop hits on to the shade??
  20. #20
    ViKiNg's Avatar
    Aug 2006
    30
    457
    3 Post(s)
    sir from where u got this rates ,here at gizri people asking 200+ per sq ft
