Page 25 of 32 FirstFirst ... 152324252627 ... LastLast
Results 481 to 500 of 639
Like Tree113Likes
Thread: Must read before buying new battery (UPS or Car)
    Ishtiaq778's Avatar
    Feb 2010
    Dina
    1,172
    81 Post(s)
    Default Must read before buying new battery (UPS or Car)
    To prolong battery life and get maximum performance must follow these points.
    1. Never Use battery without initial charging.
    2. Never charge the battery soon after putting the electrolyte in it.
    3. Leave the battery at least 25 to 30 minutes after adding electrolyte than connect
    with charger which gives 10% ampere of battery capacity.
    4. Charge the battery till it reaches 15V and, replace the battery caps, look all cells are
    producing bubbles equally.
    5. Every battery have a manufacturing date printed on it........Purchase latest newly
    manufactured one.
    6. Make sure that before adding the electrolyte, battery was completely sealed and air tight.
    7. Now some companies offering already prepared electrolyte, prefer that one, rather
    then prepared by the electrician or battery vender.
    Any query regarding battery will be honestly entertained up to My knowledge Insha Allah
  2. #481
    jamalkhanjani's Avatar
    May 2015
    23
    Quote Originally Posted by Ishtiaq778 View Post
    By the way I see you are recomending many people this homage ups but why don't you recomend people desi UPS at least they provide these type of settings which is good for battery isn't it? jamalkhanjani
    where did i recommend homage???
    Pardon me if you don't I was just going through your thread and can't recall exactly where read it...
    so which UPS do you recomend then?
  3. #482
    Ishtiaq778's Avatar
    Feb 2010
    Dina
    1,172
    81 Post(s)
    Quote Originally Posted by jamalkhanjani View Post
    Dear, i don't recommend any........Those who ask on forum what to buy..........actually most of them had decided already......They just need vote for their choice........
    That is why i avoid recommendation.............Every UPS has its pros and cons .
  4. #483
    khizar.313's Avatar
    Jun 2012
    Faisalabad
    490
    2 Post(s)
    Bhai agr apnay lagwana hoga to konsa lagwao gey?
  5. #484
    murtaza.ajmi.3's Avatar
    Apr 2015
    37
    294
    11 Post(s)
    APC UPS only ...........
  6. #485
    galant1's Avatar
    Sep 2013
    1,175
    65 Post(s)
    I'm using dt-830d Rs.200 DM actually it shows 13.42V at terminals (UPS stops charging at this point) When I spoke to Homage technician he said whenever someone request for charge setting modification we only have two types of SMD's one for 13.7V and other for 14.2V , therefore mine has 13.7v SMD, He refuse to further comment on type,number or exact location of this SMD he said its there professional secrets
    I have no other resource in hand to compare its readings I can asume that if they installed some resistance for 13.7v and my meter is showing 13.42V then it must have been somewhere betwean 13.42v to 13.7v
    dt-830d
    Must read before buying new battery (UPS or Car) - 0385
    No I don't want MagicEYE I was taking it as quality standard that howcome a company decide to install a magiceye and then change mind
    It seems I have to buy a seperate charger for these occasional current topups...........
    There is nothing wrong with DMM. Usually it display nearest and closest values of Voltage or current etc. I tell you the way to check cutoff point then update us with results:
    First note that 3 points/dots are charged and display on led display fully and when 4rth point is charging or running then measure the values of voltage at different time until 4rth point will charged- this will give you idea what is actual cutoff voltage and when all points are fully strong/charged then it will tell you floating voltage which should round about 13.66V or some near values.
    If your values are not up to spec then go to College road if you live in ISB/RWP, you will find many shops there who repair your inverter according to specs by using same components used by homage and their rates are also less then homage which ripping the people by putting cheap components on pcb and will cause many problem in futures.
    Engineer + Car's Passion = Enthusiastic Personality.
  7. #486
    May 2015
    23
    Quote Originally Posted by galant1 View Post
    Ok I started checking at 13.25V, 3 bars were stable and 4rth was flashing and then again when bars stoppped flashing & fan was stopped then voltages were at 13.42V (its same every time)
    I'm in Lahore and will try to look around if someone else can modify it, actually it is not just the charges, in the peak of hot summer it is not possible for 4 to 6 days delay at Homage service center along with insulting attitude of staff
  8. #487
    May 2015
    23
    But how do you compare homage/inverex or similar type vs desi ups?
  9. #488
    wasim625's Avatar
    Nov 2014
    1,243
    25 Post(s)
    @Ishtiaq778
    Bro i have a generator which has DC volts out too. Can i charge a new UPS battery on it? The generator DC output switch says 8 amps.
    I know batteries should be charged at a particular charge rate but due to load shedding and Jahill battery shops i don't think any new battery can ever be completely charged. So i am thinking of too prepare a new battery with pyro electrolyte and charge it continuously on that generator DC 8 amps output. Charge the battery till it reaches 14.4 volts. And check its gravity and adjust if need with distilled water. And consider a job well done.
    Do you think my generator's DC output can handle and charge the battery without damaging it self?
  10. #489
    Ishtiaq778's Avatar
    Feb 2010
    Dina
    1,172
    81 Post(s)
    Quote Originally Posted by wasim625 View Post
    @Ishtiaq778
    Yes dear..........no problem if your generator is good enough......to give 8A.....
  11. #490
    wasim625's Avatar
    Nov 2014
    1,243
    25 Post(s)
    One more question how to check gravity of motor bike battery gravity the gravity meter can't be inserted in small holes of battery
  12. #491
    khizar.313's Avatar
    Jun 2012
    Faisalabad
    490
    2 Post(s)
    Whats the correct method of charging new battery?
  13. #492
    wasim625's Avatar
    Nov 2014
    1,243
    25 Post(s)
    Quote Originally Posted by khizar.313 View Post
    Read OP man.
  14. #493
    khizar.313's Avatar
    Jun 2012
    Faisalabad
    490
    2 Post(s)
    Read OP man.
    OP means?
  15. #494
    Ishtiaq778's Avatar
    Feb 2010
    Dina
    1,172
    81 Post(s)
    Not possible with big hydrometer, smaller is not available, so only battery volts on pole state the condition of battery.....
  16. #495
    wasim625's Avatar
    Nov 2014
    1,243
    25 Post(s)
    And voltage on poles should be 12.6 or above right?
  17. #496
    wasim625's Avatar
    Nov 2014
    1,243
    25 Post(s)
    OP means?
    First post of this thread.
  18. #497
    Ishtiaq778's Avatar
    Feb 2010
    Dina
    1,172
    81 Post(s)
    yes dear............right
  19. #498
    wasim625's Avatar
    Nov 2014
    1,243
    25 Post(s)
    Ok. Thanx alot bro
    A question there is battery in one of our motorbike's this battery doesn't go above 13.9 volts when i charge it on generator. But the other battery in my other bike easily goes to 14.2 - 14.4 volts when i charge it both are AGS but one is a bit week than other. The one that doesn't go above 13.8 volts stabilises at 12.4 volts by the way Not on 12.6.
    What can be the issue?
  20. #499
    Ishtiaq778's Avatar
    Feb 2010
    Dina
    1,172
    81 Post(s)
    Ok. Thanx alot bro
    If both batteries are of same age...then one battery showing less volts a little weak but ok......not to worry if it maintains volts @ 12.4.
  21. #500
    wasim625's Avatar
    Nov 2014
    1,243
    25 Post(s)
    Ok. thanx bro
