Page 4 of 4 FirstFirst ... 234
Results 61 to 79 of 79
Like Tree104Likes
Thread: Want to buy Engine Swapped Car? OR want to Swap Engine ? think again
    afnan.bashir's Avatar
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Default Want to buy Engine Swapped Car? OR want to Swap Engine ? think again
    Swaps are considered THE ultimate solution if your neighbour tells that i swapped my engine and now my car goes like ZoooOom. .With the accessibility of used motors from their domestic markets, dropping a more powerful motor into your car is becoming increasingly cheaper. This in no way means a motor swap is easy, economical, or even a good idea. Modifying a car to the point of doing a motor swap requires two things: a huge amount of time, and an even larger amount of money. This is the basis of everything.
    Here is my Short Story of Long Problematic Swapped Engine.
    I bought a CB7 Accord which was released in 92-93 by Honda Company. This car seems very promising when it comes to various cars like hondas and civics. Its drive and comfort is even good than CF4 civic. Well all these factors led me to buy one.
    The Transmission:
    On the day of inspection i saw a swapped F18B VTEC motor and I was like YAY this is the real deal. During the period when i used to clean the car i noticed few wire connectors laying around in engine bay. First thought OOO may be someone forgot to connect something. let me find them may be car would be more of fun. Here is link to Post on Pakwheels Asking what are they for. ____ the conclusion was Aw crap my transmission is hydraulic and the transmission that came with this engine was electronic. But OK ill live with that as long as gear is working
    Why Engine wont REV over 5k RPM:
    Noticed car cant rev over 5k RPM....... why Why and then after research and spending months I knew my ECU was for Automatic Transmission and my Transmission is hydraulic and no signal is seen by ECU so it thinks car is static and it cant set various parameters. I was like i am doomed.
    The ECU:
    Next Thing was why is my car so keen to end my fuel tank........... alot of research endless sleepless night thinking of the reasons, getting help by pakwheel members, international forums I came to know Awww Crap my ECU is you got to be kidding me....... My Engine is F18B and it is connected to F23A ECU.............. this was the secret of getting 4 km/l milage. Some how i had managed to buy and put in there F18B genuine ECU.
    Why my car cant work on Scanner as it should.
    Well this is most crucial part most people dont bother. Car tells everything its going through via Cable link to Computer. All cars after 96(not suzuki of course) came with ODB2 Diagnosis port. I could not find one so could not knew what is going on. Some how i wanted to put a check engine light in my cluster. Googled and got ECU wiring schematic and shazam was ready to do that. Pulled one wire from Connector A of ECU and whole wire grip came to me. I Screamed I have killed the car............... and next i noticed well may be the electrician who did swap was a stupid guy who forgot to wire it. Never thought that its left intentionally as they dont know what and how to wire it. I took the pain and wired them in 3 months time. Boy that was some serious pain.
    Why I am getting Check Engine Light:
    Well check engine light stayed ON for all time and when i pulled the codes first one was O2. Connected the o2 and next thing light again lits at 90km/h now this was knock sensor. Now what The F18B didnt had knock sensor........ now it was ECU problem.
    Why Car runs like FX on Higher RPMS:
    Well mystery was that my fuel pump was bad and all mechanics tested by blocking the fuel pipe and if mechanic was a thin dude with less power said pump is fine and if he was strong says see i can stop the fuel coming out this means your fuel pump is bad. Iqbal Pyara also never wanted to work on my ride because it was not quick way to earn money. So i had t do it my self. Found Magic Motors and they finaly had Fuel Pressure Gauge.
    Why there is Slugish Throttle Response?
    You press throttle and wait for few seconds for power to come to you.......... why Why Why and a guru on pakwheels told me why dont you check Valve clearence. Now i was lucky to get my hands laid on AutoData Manual and came to know that Value for Intake is 0.24-0.28 and for Exhaust 0.28-0.30. Guess what my car had both set to 0.1 which means no enough intake air and less exhaust air exit time............ Crap.
    Why my spark plugs seems melted and Brown:
    Shared picture why my spark plugs are very odd in shape and color which is not comparable to any example over the internet. Why is that.Again the Guru pointed out these plugs are not for your car they belong to V6 hilux or Vitz something but they are too long which makes them to be in center of spark and get super duper hot....... I was like Phew if they have touched piston by any chance ill be in ruins.
    Why new plugs are way black than ever?
    Car was literally a fuel guzzler and i cant handle it like this way. After few sleepless weeks and tiring work, absence from office opened the injectors and came to know what the hell they are D15 Civic Injectors what are they doing there, That is why i am getting 40% fuel trim. Changed the injectors today and still think car is throwing black smoke.
    So list goes on and on and on and on. I didnt mentioned here few problems minor that i had, mentioned ones are the one which made me wake up all night. By the way thanks to Allah this car has never made me stop on road side. And May Allah keep his blessing and prevent that from happening .
    Who should go for SWAP?
    1.If you dont have habit of thinking WHY this and WHY that, then you are the luckiest person in world whose key to Happiness is Sanu Key.
    2. If you dont fear getting your hands dirty and brave enough to spend more than 4 hours daily on you ride
    3. You can google and get all data you need
    4. You are good in electronics
    5. You have determination to nail down any challenge
    6. Or you think your mechanic and Electrician will do a proper complete swap for you and wont rip you off.
    You can go for swap. Otherwise dont bother it. Normal people dont do swap they just sell off the car to someone else until car finds themselves guy like me or end up in junkyards
    There are many people here who ended up with swap but were brave enough to make the odds in their favour. like @SER_GTR, @star2, @IsbCap, and Me of Course etc
    The name of the Guy who helped me get out of this nose dive is Zulfiqar aka @Xulfiqar. May Allah be with him.
    NOTE: This is my personal experience and based on other posts made by people here and on other forums. You may or may not agree with me on above points
    So what is your SWAP Story?
    Similar Threads:
    93 Accord CB7 (Sold) / 2005 CL7
  2. #61
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Quote Originally Posted by bilalasheikh View Post
    Got it scanned, Everything was fine according to the Mechanic. Plugs were dirty, i was told to replace them with the IRIDIUM plugs. Chenged them yesterday. Being told will get 2 km / litre improvement. Fingers Crossed
    Aint gona get 2km/l just like that. Get it scanned. Take pictures of O2 graph and post. Tell us the reading of Long and Short Term Fuel Trims
  3. #62
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by afnan.bashir View Post
    It does sound like "choo mantarr tuning"
  4. #63
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Yeah
    That's what almost everyone is doing in Lahore
    Sent from my Samsung 796cc via some chain reactions..
    https://www.facebook.com/OsamaAbbasPhotography
  5. #64
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Sold that ride and got CL7. Now it apearently has less jugars than previous ones. its 90 % OEM thanks to Allah. Share your swap stories
  6. #65
    zahirm23's Avatar
    May 2015
    Hari pur
    26
    Ok so my civic 99 not going below 140km/hr 4200rpm. Does this has anything to do with the ECU? Its a VTi 1600cc auto.
  7. #66
    uzair_anjum_Siddiqui's Avatar
    Mar 2014
    Rawalpindi Cantonment
    35
    10
    What is The Correct ECU for D17A Engine. I have this installed and ECU "3H".I am facing exactly the same issues as mentioned in this thread.
  8. #67
    Mar 2014
    35
    10
    I have this ECU installed
    2001 2005 Honda Stream Civic RN1 Automatic ECU JDM D17A vtec PSA JDM D17A | eBay
    but mechanic is saying that its not correct.
    How much fuel average can i expect from d17a swapped in Accord 88.
    I installed the O2 sensors.
    According to mechanic only Auto Transmissions codes are in ECU
  9. #68
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Quote Originally Posted by uzair_anjum_Siddiqui View Post
    O boy o boy you can expect all sort of troubles if your swap is not done correctly. Here are few things you need to consider
    1. D17A engine has electronic auto transmission. Having said that it uses two sensors on transmission and calculate the speed and ECU sends that signal to Speedometer.
    2.I am sure you have not complete wiring as no body does that here. Get proper wiring done, hook ODBII DLC. Get codes and see.
    3. Your AC wont raise the rpm
    etc tons of these
    Most probably your mechanic installed different auto transmission and ecu is for automatic and when it does not sees sensors of auto transmission it makes your car go nuts.
  10. #69
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    if the ECU does not see the speed sensors input from the transmission it will go into limp mode and burn fuel like its mufft ka maal. btw - which haatometick gheyr was used to couple this engine to the car? I know for sure the accord unit wont work.
  11. #70
    Mar 2014
    35
    10
    Default help
    The electrician in pindi told me that i have to install a "Garaarii" to make VTEC on. according to him this will help in fuel. currently its giving me 8km/ltr within city and on long drive same.
    it will cost round 10000 for garari. he said that speedometer will not work afterwards.
    currently my car dont go above 5000 RPM.
  12. #71
    awais.9's Avatar
    Mar 2010
    69
    11,927
    5
    162 Post(s)
    15 Thread(s)
    if u have swapped D17 engine u were using previous D series engine then use solenoid of that engine n same ecu from previous engine, there wont b any check light
  13. #72
    Mar 2014
    35
    10
    I dont know the details . as i bought this with engine swapped. it was ussd on CNG so these issues came up when started using petrol
  14. #73
    Mar 2014
    35
    10
    How much fuel average this engine can give once ecu is working fine?
  15. #74
    searchingeyez's Avatar
    Feb 2014
    24
    534
    7 Post(s)
    i swapped my city 99 efi engine to junkyard engine that i know oldet ecu is so simple it can actually drive a khota too :p check light laane k lie baqaeda mehnat kerni parti ha :p.... so swapped the engine with oldet ecu n wiring
    no oxygen no knock sensr no cyp,no ignition coil in ecu .. only tdc iac tps map ect sensor are available . and these are common sensors in all efi engine so ecu can drive any engine having similar cc and sensors... removed o2 sensor from new engine removed distributor n installed my own dizzy , cut the wiring of ckf sensor cz my car ecu dont bother of crank position so why i should bother :p ....
  16. #75
    janleva's Avatar
    Apr 2005
    35
    1,861
    18 Post(s)
    Get THe car overhauled if the block is not cracked
    Past cant be brought back ..but future can be made even better than the Past..if one wants to.. ....
  17. #76
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    My Swap Story
    I Not Once But Did Swaps Many Times And Guess What
    I Get It Done Under My Observation And Keep Nitto Tape Electricans 20ft away from my car
    Results...They Still RUN W.o Troubling.... -_-
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
  18. #77
    zahirm23's Avatar
    May 2015
    Hari pur
    26
    Well got my auto trans swapped with manual and changed ecu and wiring as well. Good average now, got speed, and much smoother drive
  19. #78
    xub.911's Avatar
    Apr 2014
    13
    Assalam o alikum,
    i have honda civic vti oriel prosmatec 2005 but its original engine was swapped with D15B 3 stage vtec (JDM) engine
    now the car is giving me very bad mileage 7-7.5 kmpl max with A/C on in city.
    and i am skeptical about its wiring and the ECU installed (i think the ECU and Wiring was not changed at the swapping time and is pakistani ecu)
    how can I check if the ECU is correct and there is one device beside the engine that is not plugged in i am not sure what it is.
    please guide me.
    Regards,
    Ayub
    Want to buy Engine Swapped Car? OR want to Swap Engine ? think again -1592769
    this port is not plugged can anyone tell me what it is
    Want to buy Engine Swapped Car? OR want to Swap Engine ? think again -1592770
  20. #79
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Quote Originally Posted by xub.911 View Post
    Assalam o alikum,
    please guide me.
    Regards,
    Ayub
    It is EGR
