Results 1 to 5 of 5
Thread: Suggest engine for Toyota Cressida
    aamir_aijaz's Avatar
    Jan 2007
    49
    210
    Default Suggest engine for Toyota Cressida
    Assalam-O-alaikum!
    I have just bought a 1992 Toyota Cressida Station Wagon with 22R engine %-speed manual. The diff. & clutch are in bad shape. Engine & carb seems to be 9/10.
    My question is should i stick to this engine and get everything else repaired or go for a complete engine swap?
    farazarif's Avatar
    Dec 2007
    1,154
    17 Post(s)
    Are u sure it is a 22R and not a 22RE?
    Irrespective it's an excellent engine, durable, reliable, pretty decent on fuel, take off quite well with good low end torque.
    The same engine also came in the Celica of the time, why are you considering changing the engine???
    "A car is just a car unless it's my car" - Faraz Arif
    bradpit's Avatar
    Nov 2010
    42
    2,064
    87 Post(s)
    2 Thread(s)
    Quote Originally Posted by aamir_aijaz View Post
    Assalam-O-alaikum!
    Brother its best to overhaul engine if u have a good mechanic.
    If the engine is totally out of order & you are left with no choice only then u should swap
    I have seen people running 7afe engine in this car with cng
    Sent from my HTC One X using PW Forums mobile app
    All life is an experiment. The more experiments you make the better.
    Jan 2007
    49
    210
    I went to a mechanic & he said the clutch needs only service. So, he cleaned and put it back in. Two bearings in the diff. were bad. Now i have another problem, the carb has a bad coke (stuck in closed position) and the butterfly is in bad shape. The mechanic says it cannot be repaired and to change to some other carb. What should i do?
    husnainkhan's Avatar
    Nov 2007
    83
    1,359
    20 Post(s)
    Overhaul the engine rather than swapping.
    Sent from my HUAWEI Y300-0100 using PW Forums mobile app
