Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By xyber
Thread: Honda City 2004 Vario - please give suggestions
    xyber's Avatar
    Oct 2012
    52
    Default Honda City 2004 Vario - please give suggestions
    Hi,
    Buying 10 years old car (Hoda City 2004 Vario, 70,000 Kms driven) is it a right decision?
    car is in good condition both engine and body wise. What should be its right price?
    please give suggestions.
    Regards,
    Similar Threads:
    salim991's Avatar
    Jan 2012
    17
    10 year old Honda is not a bad decision at all. If everything ok...then its value should be around Rs.850,000.
    xyber's Avatar
    Oct 2012
    52
    thanks for your reply salim991.
    xyber's Avatar
    Oct 2012
    52
    other members please give your suggestion / comments.
    babarhyd's Avatar
    Jul 2005
    Hyderabad
    30
    1,956
    94 Post(s)
    4 Thread(s)
    I own similar car.
    If it has been maintained than 800,000rs is an excellent price. Body should have no Rust at all. You will not get better sedan in similar price range. Before purchasing check the gear.
    Put it in D if you hear grinding noises than probably CVT gear is near end of life.
    Check all the way to L gear.
    While driving the shifts should be very smooth from very little to no jerks at all.
    Check the tires and specially the howling sound problem which come when car is driven at 60/70kmh speeds, if you hear such sound don't worry the replacement parts are easy and cheap to find.
    Check the coolant of the car. It should be original factory one if not than remember that radiator or engine has at some point been overheated because of which owner has changed the factory coolant plus there should be no Rust in radiator.
    Check the bumpers for alignment.
    What more do u want to ask?
    z0haib's Avatar
    Dec 2013
    1,495
    19 Post(s)
    Quote Originally Posted by babarhyd View Post
    I own similar car.
    How would you know that if coolant is changed if the person uses original coolant from 3s dealer ?
    No Signature because other steal it
    babarhyd's Avatar
    Jul 2005
    Hyderabad
    30
    1,956
    94 Post(s)
    4 Thread(s)
    Quote Originally Posted by z0haib View Post
    If the owner has been good enough to replace the coolant with original oem one than at least you can trust him. Next is rust in radiator.
    xyber's Avatar
    Oct 2012
    52
    dear babarhyd thanks for your detailed response.
    regards,
