Results 1 to 7 of 7
Like Tree4Likes
  • 1 Post By mobe1
  • 1 Post By Titanium
  • 1 Post By IsbCap
  • 1 Post By Arib
Thread: Isb to Rajanpur, which route to take?
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Default Isb to Rajanpur, which route to take?
    Have to move to Rajanpur this or coming weekend. Which route would be best:
    1. Isb-Chakwal-DI Khan-Bhakkar-DG Khan-Rajanpur (698 KM)
    2. Isb-Faisalabad-Khanewal-Multan-DG Khan-Rajanpur (767 KM)
    Need info specifically about the road condition of first option. Is it two way or one way road?
    Would appreciate opinions from members who have recently traveled to this area...
    Isb to Rajanpur which route to take? -1501502
    mobe1's Avatar
    Oct 2014
    Multan
    28
    If u r moving early in morning then option is better. U ll exit from balkser to chasma. From there u ll go to di khan. Then its straight 360 km indus highway. Its a single road from balkser...
    Titanium's Avatar
    Sep 2007
    Dera ismail khan
    42
    513
    5 Post(s)
    Default Islamabad to Rajanpur
    Road conditions on your first route
    Isb to Balkassar - Motorway
    Balkassar to Mianwali - Single but fine and wide enough less the Musakhel-Mianwali section which is broken with potholes
    Mianwali to kundian more - Broken and under construction with diversions intial about 7 kms, later fine
    Kundian more to chashma - Single, narrow with potholes
    Chashma to DI Khan - Under construction with frequent diversions
    DI Khan to DG Khan - Partly fine but mostly broken due to heavy traffic
    DG Khan to Rajanpur - Same as above
    Suggestion
    You may like to consider the following 3rd option
    Isb to Rajanpur which route to take? -1501721
    From Mianwali take the MM road to Muzaffargarh, cross over indus to DG Khan and then Rajanpur.
    This would save you distance and also keep travelling on the east of indus within Punjab with relatively better road conditions.
    Of all the things i have lost, I miss my MIND the most...
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Quote Originally Posted by Titanium View Post
    Suggestion
    Beautiful. Thanks a lot for taking time to compile such a detailed info. Help really appreciated.
    Arib's Avatar
    Aug 2009
    36
    285
    11 Post(s)
    Quote Originally Posted by IsbCap View Post
    Dear If go via Multan, there are two routes
    Route 1
    1. Islamabad -- Faisalabad Motorway
    2. Faisalabad -- Jhang Road is 2 way and ok
    3. Jhang -- Kabirwala -- N5 Link Road Road is 2 way & good with few bad patches
    4. N5 Link Road -- Multan Road is very good
    5. Multan -- Muzzaffargarh Road is very good
    6. Muzzaffargarh -- DG Khan Road is 2 way and ok
    7. DG Khan -- Rajanpur no idea
    Route 2
    1. Islamabad -- Pindi Bhattian Motorway
    2. Pindi Bhattian -- Chinniot -- Jhang Road is 2 way & ok
    3. Jhang -- Rajanpur same as above 3 to 7
    If you follow Pindi Bhattian route than distance will be around 50km less than Faisalabad Route.
    I have No Signature, I Use Thumb.
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Quote Originally Posted by Arib View Post
    Route 1
    Route 2
    Thanks for detailed info. I usually prefer the motorway and one way routes even if they are 10% longer, due to peace of mind and safety (Plus it consumes lesser fuel due to continuous drive in higher gears)
    Have moved to Bhawana (In between Jhang and Chiniot) 2-3 times via Pindi Bhattian. The road is almost perfect.
    Btw, M4 has been constructed uptil Gojra, and will be started formally in December this year.
    Arib's Avatar
    Aug 2009
    36
    285
    11 Post(s)
    If you have traveled till Bhawana than road ahead of Bhawana till N5 is approx. same with 1 bad patches after Jhang but not very bad.
    If you have to travel in December than M4 will be best option.
