Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 140
Like Tree4Likes
Thread: suzuki liana tip/maintenance thread
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Default suzuki liana tip/maintenance thread
    I have decided to start this thread as this car is very badnam of having hard maintain car which I don't think is right so I have started this thread to help every liana owner facing any type of problem is his car
    error codes suzuki liana in link below
    suzuki liana error codes
    suggstion/tip/solution to every cng problem with suzuki liana
    solution to every cng problem of suzuki liana
    The coil burning problem
    solution to coil burning problem
  2. #61
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by salahuddin99 View Post
    any shop name or persons contact
    Sent from my GFIVE President(G9) using PW Forums mobile app
    key issue solved ?????????
  3. #62
    a_k
    a_k is offline
    a_k's Avatar
    Feb 2005
    39
    2,012
    4 Post(s)
    RXI, nov 2008 reg, 52K driven, petrol
    problem is it runs perfect without a/c, but with a/c it loose all power, someone told me that get the version of software checked of ECU!?!?
    second, what to do with suspension, i can feel every small stone, up/down while driving? tires are general.
    what is the normal kmpl for this car in karachi city a/c no a/c?
    thirdly do we need to service throttle body every time we do regular maintenance? @Xulfiqar
    If better were within, better would come out.
  4. #63
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by a_k View Post
    first tell your the first owner or you have bought it from some one
  5. #64
    a_k
    a_k is offline
    a_k's Avatar
    Feb 2005
    39
    2,012
    4 Post(s)
    ^first owner
  6. #65
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    ^first owner
    how long your are facing this suspension issue and the issue of power loss on ac it was present form the first day or it started some time back when was the last time you got the throttle body suffered are you using your car on cng if yes which type o f cny local or ff (fatory fitted) cng
  7. #66
    a_k
    a_k is offline
    a_k's Avatar
    Feb 2005
    39
    2,012
    4 Post(s)
    loss of power means, requires down shifting, its not like engine is dying, but i can feel difference in engine power,
    car is petrol
    suspension in other liana is also same as mine, it means its common complain, bumpy, otherwise grip and drive is great,
    my view about this car is quite positive.
  8. #67
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    car is petrol
    it really a good thing to read that you have positive review about liana I also have a liana and I don't think its suspension is hard keep tire pressure 33 psi at fron and 35 psi at rear and every car loss some power with ac how much it losses power 20% is fine
  9. #68
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    self edited
  10. #69
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Bump..
  11. #70
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Bump..
  12. #71
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Bump..
  13. #72
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Bump..
  14. #73
    giftedsoul's Avatar
    Nov 2014
    33
    3 Post(s)
    Quote Originally Posted by saboor73 View Post
    @saboor73, your mentioned values of Tyre pressure are for which size of tyres, mine are 185/65R/15 ... keeping at 30psi normally, should I raise some more?
  15. #74
    giftedsoul's Avatar
    Nov 2014
    33
    3 Post(s)
  16. #75
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by giftedsoul View Post
    you should if you want better economy
  17. #76
    Proverbial_Slang's Avatar
    May 2005
    3,904
    29 Post(s)
    Any idea of prices of various qualities on Coils and plug towers?
    Death is not the greatest loss in life. The greatest loss is what dies inside us while we live.
  18. #77
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by Proverbial_Slang View Post
    to be honest no idea my car never gave coil problem are you facing coil problem I would advice u to replace you plug with Iridium I think the no of plug would be IK20 plug will cost you 4600 for four plug
  19. #78
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Bump..
  20. #79
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Bump..
  21. #80
    saboor73's Avatar
    Oct 2013
    10,548
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    AOA bro sorry I misguided you a lil your car is RXI so your car will without Alloy that the reason your are felling every bump on road mine is Lxi it have factroy fitted alooy that why my drive is very smooth
