Page 7 of 7 FirstFirst ... 567
Results 121 to 140 of 140
Like Tree4Likes
Thread: suzuki liana tip/maintenance thread
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Default suzuki liana tip/maintenance thread
    I have decided to start this thread as this car is very badnam of having hard maintain car which I don't think is right so I have started this thread to help every liana owner facing any type of problem is his car
    error codes suzuki liana in link below
    suzuki liana error codes
    suggstion/tip/solution to every cng problem with suzuki liana
    solution to every cng problem of suzuki liana
    The coil burning problem
    solution to coil burning problem
  2. #121
    Proverbial_Slang's Avatar
    May 2005
    3,904
    29 Post(s)
    Quote Originally Posted by saboor73 View Post
    185/60/15 are same as 185/65/14 stock tyre
    Yes you are right. Im asking if these prices are good and if there are any other good options available in the market.
    Sent using Curiosity's onboard communications sytem.
    Death is not the greatest loss in life. The greatest loss is what dies inside us while we live.
  3. #122
    Newbie Follow
    alex08's Avatar
    Jan 2015
    hi guys, I have a suzuki liana 1.4 ddis , a few months ago broke the timing belt , I took her to the service, the driver changed and said that something is not broken anything other. After 4-5 thousand kilometers, I came spiral board and chek engine. Hold your fire engine, not raise speeds above 3200 rpm. I went to the service and were repaired injectors. After this 3-cylinder engine work.It was mounted injector not believing that he is out of work, but it was good. After installing all the place, the engine does not want to start. These faults occur after a diagnosis: P1207 , P1163, P0102, P0266,P0264. Errors have been removed, but one remains : P1207. The engine just does not start. A ramp was measured pressure and is very small, plays between 6-28 bar. By the time must be at least 280 bar . What is itPlease help me !!! Thank you !!
  4. #123
    May 2005
    3,904
    29 Post(s)
    Quote Originally Posted by alex08 View Post
    I'm sorry but I didn't understand your problem.
  5. #124
    abid110's Avatar
    Jan 2014
    3,894
    90 Post(s)
    Waqai, kuch samajh nahi araha kya likha hai...
  6. #125
    tahahaq's Avatar
    Apr 2015
    11
    Dear Brother
    Will you kindly comments on following which will be beneficial for all
    1. How did you reset the ecu ( with software or with removing the -ve terminal )
    2. Please describe some more on AFR sensor , how did you do it . did you affix new or repair or else
    Thanks for sharing all these
  7. #126
    tahahaq's Avatar
    Apr 2015
    11
    the second gear problem in liana I never admitted the fact that liana have any second gear problem becoz I never had one in my live and drove countless liana but a friend faced the second gear problem so I was the one advising him to for the car he came to me and on trying to find the solution I found that not only second but all the gear are performing less then I idle i was shocked and as second gear is shortest in liana so it driving are felt there problem in only second gear I rested the ecu,changed plugs,coils everything but nothing work I asked the owner did the car back/fired he said yes by just tooka I guessed it AFR sensor which just got damaged due to back/misfired I got on from AFR sensor from one half cutted japnese liana putted in the car and rested ecu and car becoz became smooth as silk
    Dear Brother
  8. #127
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by tahahaq View Post
    Dear Brother
    It was not AFR sensor it was past O2 sensor it I wrote AFR by mistake the O2 was kabli (used) i don't believe in resting of ecu by removing battery terminal i used this relearning procedure
    suzuki liana tip/maintenance thread - 1541696d1418294453 vitz jerking vibrating 1418294304071
  9. #128
    musafir1's Avatar
    Nov 2011
    109
    6 Post(s)
    Dear saboor73 will u pl send me ur Cell # in box?? as I want to sale my Crolla 08 and wl buy Liana 2011-12, but I m confused due to comments of my mechanic and friends
    thnx in advance
  10. #129
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by musafir1 View Post
    thnx in advance
    Pmed..
  11. #130
    enthusiastic.learner's Avatar
    Jul 2015
    571
    8 Post(s)
    Assalam-o-alaikum Pakwheelers.
    Lately I have been facing an annoyance with my Liana 2006 RXI whereby the seat belt lights turns on at random and sometimes stays ON even though I have turned the car off using the key. Also, the roof ceiling bulb turns ON on its own at times and there seems to be some sort of connection interference between both lights. As in, when I turn on/off the ceiling light a couple of times, the seat belt light turns off. Sometimes when I come back next morning, I find both ceiling light and seat belt light ON on their own. What's happening? Is there a loose connection somewhere? If yes, then where exactly could it be?
    Also, i've noticed that the seat belt lights turns on even if I have buckled my seat belt properly along with my partner on the left front seat.
  12. #131
    hasooboy's Avatar
    Feb 2010
    29
    5,401
    81 Post(s)
    3 Thread(s)
    Quote Originally Posted by enthusiastic.learner View Post
    Do you have imported one? Jdm ?
    Sent from my GT-I9500
    Boy Badnam hua LIANA tery liya
  13. #132
    Jul 2015
    571
    8 Post(s)
    Quote Originally Posted by hasooboy View Post
    I believe that 2006 model RXIs were mostly imported. Correct me if i'm wrong.
  14. #133
    hasooboy's Avatar
    Feb 2010
    29
    5,401
    81 Post(s)
    3 Thread(s)
    Yeah 2005 and 2006 early version most of them were imported jdm, your one should have a air bag and hidden tray beneath the seat. As local pkdm doesn't have any seat belt warning light. I don't know how to solve this issue better post it on liana fan club.
  15. #134
    Jul 2015
    571
    8 Post(s)
    Just double checked. Mine is imported and even has airbag system installed. (Y)
  16. #135
    rainnn's Avatar
    Apr 2009
    46
    Default Suzki laina petrol average and missing and engine check light
    Quote Originally Posted by salahuddin99 View Post
    when i took out the fuel pipe when switch is on it just through little bit amount of fuel.....
    and bro what about the check engine light blinking
    Dude he gudie u wrong u immobilizer allow u to self rotating but engine never start and first u u should check ur engine with lamda scanner they will tell u the error of a engine simple is start plz donot miss guided
  17. #136
    tahahaq's Avatar
    Apr 2015
    11
    Default Just Brought Liana
    Dear Brothers
    Alhamdulliah , after a year of reading all Senior suggestions and feedback in this forum, We brought Liana Petrol.
    Experiencing Smooth Drive of Liana.
    I like to have Senior Members Suggestion.
    When two or three persons sits on back seat its Silencer and bottom touches the big Bumps on Road.
    Some suggest put spacer , some suggest do not ( it will not drive smooth when back seats are Empty)
    Please suggest what to Do?
  18. #137
    hash737's Avatar
    Jan 2010
    1,073
    31 Post(s)
    Dear Brothers
    h
    how is your experience with liana?
  19. #138
    abid110's Avatar
    Jan 2014
    3,894
    90 Post(s)
    Dear Brothers
    Every car touches ground when 2/3 people sits behind...even corolla civics citys do it...esp on bumps..since you dont have cng cylinders so the load is comparatively lesser too..dont go for spacers..if all is fine, keep it running as it is and just be very cautious on bumps...
    Sent from my QMobile Z10 using Tapatalk
  20. #139
    eagle1234's Avatar
    Jun 2015
    95
    Check your shocks by pressing on the side of the car count how many times it rocks. If they are not equal number your dampers need replacing.
    Sent from my XT1032 using Tapatalk
  21. #140
    azyy's Avatar
    Feb 2010
    266
    4 Post(s)
    2 Thread(s)
    I changed the spark plugs and RPM started to behave rough and mild missing. are the plugs bad or some other issue. Coils are in best condition.
