Results 1 to 5 of 5
Thread: Pyro Coolant query?
    anc
    anc is offline
    anc's Avatar
    Mar 2007
    Rawalpindi
    1,051
    38 Post(s)
    Default Pyro Coolant query?
    Would like to know about the quality of Pyro Coolant? Is it a long life coolant? Should I go for it or would toyota coolant be a better option.
    Click here for SOLUTION
    tintin1's Avatar
    Jan 2014
    1,829
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    Toyota Coolant is OK. Its pre-mixed.
    or ZIC Super A is also good. Its also pre-mixed.
    or LM coolant is good as well but we have to mix water in it by ourself all depending upon requirements. Some requires 30% Coolant & 70% Water, some requires 50/50, etc.
    Be Addicted To Help Others.
    masters1001's Avatar
    May 2012
    34
    82
    M using toyota long life coolant in margalla...
    Sent from my GT-I9505 using Tapatalk
    Glioblastoma's Avatar
    Oct 2012
    316
    27 Post(s)
    Top coolants include toyota around Rs.2600 prediluted. Caltex around Rs.900 per bottle concentrated. Honda prediluted Rs.800 per bottle. Cheapest of them all and prediluted Fuchs Rs.1400. You can get fuchs from hascol pump. Personally using Fuchs.
    Most other like ZIC, NASA, osaka, pyro, guard are all not that good.
    May 2012
    34
    82
    In xli using toyota coolant since 2 years...so now started uaing in margalla as well
