Results 1 to 7 of 7
Thread: urgent help calling xperts
    saqib84's Avatar
    Mar 2008
    32
    970
    23 Post(s)
    Default urgent help calling xperts
    Aoa..i m gona buy one indus car.i found this part little crack n rusty.want to kniw that this thing will impact resale or not?or should i buy it?
    uiv
    uiv is offline
    uiv's Avatar
    Jan 2006
    1,683
    67 Post(s)
    Is it a crack in the metal or paint? Just make sure it's not cracked putty, and this car has not been in an accident.
    Is it just me or those bolts, 2 of the three, look quite desi? Even the Washer size is not the same on those, and third one- that actually look more legit- hasn't got a washer at all. This might not look important, but I do look at those things in a car.
    Sorry for being so pedantic, but it's always better to look twice. Better off wehmi than sorry.
    Good luck.
    saqib84's Avatar
    Mar 2008
    32
    970
    23 Post(s)
    @uiv its crack in the paint..didnt see putty in it..due to rust bolt looks like desi...
    uiv
    uiv is offline
    uiv's Avatar
    Jan 2006
    1,683
    67 Post(s)
    Quote Originally Posted by saqib84 View Post
    The one at the right is rusted as well, that doesn't look desi, and washer sizes are suspicious as well. In fact it looks like using washers and over torquing the bolts have caused the paint/putty to crack at first place.
    Factory paint shouldn't crack like that IMO. Better check again.
    saqib84's Avatar
    Mar 2008
    32
    970
    23 Post(s)
    @uiv thanks bro.i guess i should avoid it
    uiv
    uiv is offline
    uiv's Avatar
    Jan 2006
    1,683
    67 Post(s)
    Just take a denter with you- don't leave it altogether- I could very well be wrong.
    Can you post a wider picture?
    harib4u's Avatar
    Dec 2013
    3,436
    6
    113 Post(s)
    its fine no problem. buy it
