Results 1 to 2 of 2
Thread: air trapping in cooling system
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Angry air trapping in cooling system
    AOA guy here are my lil info about air trapping
    Why air traps in cooling system
    hmm the cause of air traping in cooling system is while toping up the level of coolant (tap water in pakistan) the air between fresh water and old water couldn't get out becoz of very narrow way out
    COns of air traps
    the bubble in coolant that are due to air in coolant doesn't let coolant flow properly and cause engine to over heat (I could be wrong on this point as it not any copy paste article from internet and just my observation but traped air in cooling system can cause car to overheat)
    Why the air trapping issue is not present in all car
    air trapping issue occur in only some car which have their radiator are mounted higher than engine
    common car which have air trapping issue are
    suzuki liana (vuru and simple both)
    honda civic 95 aka dolphine
    Solution
    well try to pour coolant in your car the car running on tap water need to topped up their coolant again again which cause air trap between fresh and old water if you want to pour water than take a pipe which touches bottom of radiator suck the air out and fill water in it I will like the expert to shed some light on this as well as I am just stupid common guy with a lil info and some time little info is more dangerous than having no info at all
    P.s if you find any mistake in article plz correct
    COOLTAHIR's Avatar
    Feb 2011
    Select City
    19
    4,702
    9
    132 Post(s)
    3 Thread(s)
    Nice information
    FeeL YoUng DriVE YoUnG......
