Results 1 to 5 of 5
Thread: 22R Startup noise
    najeeh's Avatar
    Jul 2014
    153
    3 Post(s)
    Default 22R Startup noise
    Hello,
    I've got a toyota 22R in my car. A few weeks back water got mixed with oil due to the plastic timing chain guide being broken. I got the engine cleaned out and replace the timing chain. guides and gears. Now when I start it up cold or when it has been sitting for ~15 minutes, the is a very loud knocking or hammering sound for 2-3 seconds. After this time its gone. I thought the oil pump wasn't pumping fast enough so I got it replaced, but the sound is still there.
    Any Idea on what it could be?
    umarpal7's Avatar
    Mar 2011
    28
    632
    2 Post(s)
    maybe its the noise of your crankshaft, may be I am wrong but a serious knock like this could only be made if the crank shaft is grinding
    najeeh's Avatar
    Jul 2014
    153
    3 Post(s)
    Quote Originally Posted by umarpal7 View Post
    If the crankshaft is grinding then i would hear the sound on harsh acceleration but I dont. It has to do something with the oil supply and some as the gauge cluster shows me an oil warning light for the first 2-3 seconds of the engine being started. When the warning light goes out the sound does too. A little more background, this sound was not being produced before the oil and water problem.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    your crank bearing shells are bad - they have too much clearance, the sound is usually a dull rumble till the light goes out. This happens after a water/oil mix problem as the water/glycol damages the babbit bearings. You will need to remove the engine and remove the crankshaft to replace the bearing shells.
    najeeh.siraj's Avatar
    Oct 2012
    This is the sound I'am talking about:
    Don't mind the loose alternator. It has been fixed.
