Since the Displacement of Corolla (1298) and City (1300) is almost equal, Why Corolla offers much less power (84hp@rpm) than City (100hp@rpm)?
How do we calculate hp and Torque?
Consider the weight of two vehiclescity is lighter than rolla
Engine Torque | Engine Powerthis will help you understand how to calculate
Why ? i don't know ... 1300cc only means 1300ml... it is not an indicator of engines power as new suzuki alto in japan produces 64hp from an engine of 660cc ....these things may show engines efficiency may be ... and on the otherhand swift engine produces just 62.5 KW @6000 rpm(1328cc) ...
I have driven 2012 and now 2015 regularly and I found 2015 feels a bit more powerful than the previous one.
At lower rpm's corollas hv a better pull / low end torque
But if u do 0 to 60 or top speed check city wld b up
IMC have played a dirty trick with 1.3l corolla buyer the speedometer show much high speed than real and usually ppl assume they are going fast
OK city is lighter now explain 77hp @ 4.4k 2nzfe on flywheel compared to l13a 89hp @2.2k on flywheel
My personal car is 1800cc so my judgment is not based on speedometer only.
Really?How much is the variance
@op the 2nzfe is 15 year old tech in most Toyota cars 2nzfe is replaced by 1nr-fe the reason l13a produce more HP is becoz it made to perform l13a is under square engine while 2nzfe is oversquare plus l13a operate on intake valve for performance on low rev and VTEC on high rev
Different at different speeds? Above 100 its 20
no wonder a 1.3 new gli owner said his car touched 180 on motorway
Similarly if city produces more power only because it is lighter than corolla then what about swift, it's a 1328cc car then why does it produces less power than city?
Please support your claim with evidence. Recently a friend got speeding ticket on Motorway in his 11th Gen GLi M/T, he was going at 135 and the speed gun read 135 as well.
Will try to post pic of comparison of speed with gps
I have checked with Gps. .its almost the same, wil post the pics.
Sent from my SM-N910G using Tapatalk
There will be difference in it. The reason is GPS has a reading in digits while speedometer has a reading in analog.
because city engine has i-vtec which produces more power at higher rpm
Bro, take a moment to think before you speak, do you not think people would notice if something like this had happened. Ridiculous statement
