AOA fellow pakwheelers! can you tell me where I can find high octane in hyderabad? And If I use octane booster on petrol, will it work? Does it really boost octane level?
iam in search of high octane in hyd since ages but couldn't find till date regarding octance booster i also have same querry.
sent from iphone 6 using my thumbs
Octane booster work but lead will chock cat con of your car which car you want to feed hi octane anyway?
Got civic with f20b
My car knocks alot! High octane available at jamshoror or highway near hyderabad?
So does it knocks on regular fuel
Yeah!!!
The recommend fuel for f20b is high octane I think so as this comes with higher compression ratios! Will using normal fuel cause harm to engine?
If your engine knocks than you are surely damaging it
Any possible solution? Should I start using octane booster or should I get high octane from karachi but that will be hard to get regularly?
Colder spark plug are solution to knocking but finding non common parts in pak Is a big task it self getting hioctane from Karachi' is not a good idea get octane booster btw are you using hot air intake?
Will having colder spark plugs completly solve the knocking? Or will car still knock of I continue using normal fuel! Nop not using hot air intake! Will try to get my hands on octane as quick as I can!
Octane booster I mean!
Colder spark plug are used on very high compression engine they can help you get rid of knocking
But as you said they are rare and i couldn't myself find them around internet! Btw any recommended octane booster product?
Liqui moly is the most easily available octane booster
Will try to arrange a octane for a month from karachi along with some octane boosters! I am in hyderabad till june only and then will shift to karachi and start using octane regularly!
@saboor73 bro I have asked my cousiom who lives in karachi to buy octane booster but I don't know how many bottles should I get like how much booster is need for full tank with petrol?
It depend buy one bottle pour half of it of fuel tank if it doesn't work pour remain half as well
