Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Like Tree2Likes
Thread: GLi performance problem
    ahsandon007's Avatar
    May 2011
    Faisalabad
    105
    Default GLi performance problem
    I have Gli 2011 model with 55,000km millage .I have experiencing car performance issues .I feel that my car acceleration/power is not good...And I also noticed bit noisy engine...I change oil at every 4000kms and oil filters too...I need suggestions about any service so that my car can perform well.
    asim510's Avatar
    Nov 2009
    33
    3,393
    72 Post(s)
    3 Thread(s)
    r u the first owner ? seems like clutch plates issue, but this usually happens after 150k
    Before you criticize someone, Make sure you are better than them.............
    May 2011
    Faisalabad
    105
    Quote Originally Posted by asim510 View Post
    Yup 1st owner....i don't think so its clutch issue...:/
    May 2011
    Faisalabad
    105
    I once pour petrol from some local pump I think after that I'm facing this issue...maybe fuel quality affected that
    bakhtbaryar's Avatar
    Jun 2015
    23
    82
    Knocking is the issue... use a petrol cleaner with a full tank and put in high octane a few times a month.
    May 2011
    Faisalabad
    105
    Quote Originally Posted by bakhtbaryar View Post
    You mean fuel injector cleaner addictives?
    Guide me furtherr about how to use and which one plz.
    Farzad's Avatar
    Jun 2009
    31
    29
    Lightbulb Get your catalytic converter checked out...
    One of the main reasons of loss in power/acceleration or general load on engine is a clogged catalytic converter.
    Basically your car might not have a free flow exhaust. Cars in Pakistan commonly get a clogged catcon at about 30-60 thousand KMs.
    ~~~~~Riders on the storm~~~~~
    shabbir.53's Avatar
    Jul 2013
    63
    690
    7 Post(s)
    I had similar problem. Got catalytic converter cleaned. Problem disappeared.
    May 2011
    Faisalabad
    105
    Whats price and can I get this job done by local mechanic?
    May 2011
    Faisalabad
    105
    1.3 gli has catalytic converter?
    Jun 2015
    23
    82
    As far as I remember, my Gli 2011 March Crystal lights version had no catalytic converter. Plus your car is driven around 50k catalytic converter should not be clogged as such but it is worth getting it looked at.
    I should suggest using a good quality petrol cleaning additive (any good imported brand from a reliable place is fine), and put in high octane a few times. Try to see if the sound improves and performance goes up.
    Here is a list of what you should do in order
    1) Add cleaner and high octane and see if it helps
    2) if it does not, have spark plugs replaced complete tuning done and reset the computer
    If the above do not work (they should inshAllah, its a new car)
    3) Have its air to fuel ratio checked
    3) Have fuel injectors cleaned and the fuel pump checked
    3) Get a compression test done (Especially if the car has been driven on CNG)
    My brand new gli '16 gives me knocking and poor acceleration on bad fuel!
  12. #12
    May 2011
    Faisalabad
    105
    Thanks for reply..
    I need you to answer few qs.
    Petrol cleaning addictive or fuel injector cleaner is it same thing?
    I have driven my car 16000km after changing plugs...And no cng totally petrol driven.
    And what you mean by complete tuning what things are included in that?
  13. #13
    biloo's Avatar
    Sep 2004
    33
    1,289
    16 Post(s)
    Cat converter came in 2013 onward models. And your car has no problem , trust me. Just change ur fuel station or maybe get some hi octane poured in ur tank.
    Sent from my SM-N910G using Tapatalk
  14. #14
    May 2011
    Faisalabad
    105
    Ok I'll pour hi octane in my car
  15. #15
    biloo's Avatar
    Sep 2004
    33
    1,289
    16 Post(s)
    Quote Originally Posted by ahsandon007 View Post
    Do share the results
  16. #16
    May 2011
    Faisalabad
    105
    I poured fuel cleaner and hi octane I noticed improvement..
    Now I'm gona change plugs
  17. #17
    biloo's Avatar
    Sep 2004
    33
    1,289
    16 Post(s)
    Fuel additives are not recommended i reckon. Hi octane only would have done the job.
  18. #18
    haseeb.basharat's Avatar
    Mar 2015
    1,636
    43 Post(s)
    When was the last time you changed plugs?
    If haven't changed, than change immediately them to Denso iridium plugs.
    Genuine/OEM lasts only 30k kms
  19. #19
    May 2011
    Faisalabad
    105
    Quote Originally Posted by haseeb.basharat View Post
    I don't remember when I exactly changed plugs...I think its 16k kms or 26k kms ...not sure but ill change it soon...no doubt irridium plugs has more milage but are expensive :p...so ill use simple one and change it after every 20k kms ..
  20. #20
    May 2011
    Faisalabad
    105
    Quote Originally Posted by biloo View Post
    Ok bro thanks I'll not pour addictives nxt time
