Results 1 to 5 of 5
Thread: Cultus Brake Issue
    altafmushtaq's Avatar
    Jun 2016
    11
    Default Cultus Brake Issue
    Dear All,
    i have a problem in cultus Brakes, sometime my cultus 2005 brakes very well but sometime when i push slowly the brake paddle it completely pushed at the end and brake is not applied.
    Kindly advice what is the problem because mechanic is not understand the reason.
    Suzuki Motor said to change the following parts.
    Disk Pad, disk plate, Rear Break show, & rear wheel drum.
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    You have leak sonewhere in braking system or its just air in braking system
    Mirza967's Avatar
    Oct 2011
    23
    242
    3 Post(s)
    Quote Originally Posted by altafmushtaq View Post
    Dear All,
    your brake system rubber hoses are worn out + your brake fluid is old + your master cylinder has become worn due to old brake fluid most probably.
    haali's Avatar
    May 2010
    Other
    669
    2 Post(s)
    Your brakes will be fully 'Failed' anytime, partially they are. try to find a professional mechanic, may be this issue is just improper adjustment of brakes,
    Always remember, the best things in life are not things.
    eagle1234's Avatar
    Jun 2015
    95
    Your brakes needs bleeding as it got air in the brake cylinder there is a bleed valve in every caliper press the brake pedal and open the bleed valve the fluid should go in a container with the brake pipe connected to it you will see air bubbling continue till no air is bubbling tighten brake valve after you let go of pedal.
    You need to do all 4 wheels back first then front passenger and driver side.
    Check the brake fluid if its black it needs replacing.
    Another mention is that it could be your cylinder or pipe is perished in both cases they need replacing and the brake fluid needs bleeding.
    If you replace the rubber hose clamp it first or attach brake bleed pipe to the container in both cases they brakes need bleeding
    Sent from my XT1032 using Tapatalk
