Results 1 to 6 of 6
Thread: ignition timming
    chviky's Avatar
    Sep 2005
    Rawalpindi
    36
    164
    Default ignition timming
    Bro's i have replaced the ignition coil. My car starts now but as i have no timing gun so how can i set the fire timing correctly.
    When i rotate the distributor anticlockwise the RPM drops and when i rotate it to clockwise RPM increses.
    Manual says the setting on 12 degree.
    i have also set it in mid as i dont know how to measure degrees??? but my car is not climbing a small slope in 1st gear on CNG after that.
    Plz guide that should i set distributor at position where the RPM goes very high???
    Thanx!!
    Do you think that the ALLAH has created heavens and earth and all lies in b/w them in Play? Dust will turn into the Dust ALLAH HU AKBAR!!
    imranbhatti's Avatar
    Nov 2005
    39
    4,373
    80 Post(s)
    11 Thread(s)
    If u wana do it with out timing gun then u have to proceed with hit & trial method try on diffrent position & check throtlle response of engine. As per my poor information spark timing for CNG shud be slightly advance as compare to petrol because of diffrent burning time of both fuels. Start from position where engine RPM increases then slightly move the distributor to other positions.
    Exploring Machines is my Passion...
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    23 Thread(s)
    you have retarded the timing. note it the other way and adjust after some hit and trial
    Keep a cool head and wear seatbelts!
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    First try to set the spark timing on petrol. Start slowly rotating clockwise and give sudden throttle at each position (better keep one hand on the distributor and other on the throttle). The position at which the throttle response is good and there is no knock is the exact position of spark timing.
    Now convert to CNG and rotate a little bit clockwise.
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
    LOGAS's Avatar
    Dec 2006
    57
    1,921
    @Chviky....................
    As spectra said do it, I just add more for your convenience that during the setting keep your car on petrol, where it knocks very slightly on petrol by giving throtle, that is the best position for cng.
    Economy With Security And Durability.
    chviky's Avatar
    Sep 2005
    Rawalpindi
    36
    164
    Thank you all
    can i use a cdi distributor instead of the point type if yes from where i can get it in RWP/ISD.
