Results 1 to 7 of 7
Thread: What all to check in daily inspection of mehran
    moonnightingale's Avatar
    Aug 2008
    34
    43
    Default What all to check in daily inspection of mehran
    AOA, i have purchased car for the first time.My car is Mehran.Kindly tell me what all i have to inspect in the car on daily basis before driving. Secondly what all should i check before long drive.
    One more question, Should the radiator be kept full of water or we have to put new water after some distance for example after every 400 to 500 KM we should fill the radiator again?? do tell me.Thanks
    MoizIrfan's Avatar
    Dec 2007
    Dubai
    26
    1,960
    106 Post(s)
    check ur engine oil and brake oil on weekly basis.
    radiator water/coolant should be checked daily.
    always keep ur spare tire,jack,spanner ready
    when u start ur engine in the morning dont give aggressive throttle leave it for 5 min.
    drive safe and if u could change ur brakes to power brakes
    cuz i have heard a lot of accidents of mehran due to weak brakes
    I was driving it by a kind of instinct, only I was in a different dimension...............................Ayrton Senna
    Sabiqoon's Avatar
    May 2004
    52
    74
    Refilling radiator every 500 kms is unheard of. Also, even when doing so, don't open the radiator cap. Fill the attached bottle instead.
    There is nothing more expensive than a cheap Mercedes Benz.
    dodgy's Avatar
    Sep 2007
    53
    155
    No need to replace radiator water just maintain its existance.
    Let Individuals Fully Expand --- volunteering can change our fate
    UncleKracker's Avatar
    Aug 2006
    Musafir khana
    5
    2,663
    2 Post(s)
    First of all congratulations on buying a car. You didnt say if it`s a new or used car that you have bought. Each would require different maintenance, but the basic stuff is the same.
    Assuming it`s a new or relatively new car or even an old one, you can check the brake fluid, engine oil, radiator water level etc for a couple of days straight and once you are sure it`s not consuming oil and there is no leakage you should check them on weekly bases i would suggest.
    There is no need to check the water every 400 or 500 kms. Keep an eye on the temperature gauge while driving and you should be fine. Water should be checked regularly but isn't such a big issue in winters. Also, while checking the radiator water if you are in the middle of a long journey make sure that the engine is running when you remove the radiator cap.
    Make sure that your spare wheel is actually something you can use when needed and check the tire pressure in it when checking the rest of your tires.
    Lastly there is no need to let your car run for 5 minutes in the morning even in extreme cold. 45 seconds to 1 minute is enough. Just make sure you don`t rev up the engine in a cold start.
    I am sure other members will point out things and help you.
    Drive safe.
    Come back, Luca Badoer, all is forgiven.
    saz85's Avatar
    May 2008
    31
    40
    accept my congrates on buying a car..
    wel..
    you dont need to change the radiator water after 500km or so..
    just maintain the Water level.
    do check ur radiator on daily basis..
    check Engine oil level wkly .
    and notice your engine for leakages frequently.. coz leakage is the only cause leads to droping engine oil level or gear oil level...
    check Break fluid wkly....
    change ur engine oil after 2500km along with oil filter and Airfilter ( changing of air filter is conditional,depending up existing Condion )
    dont let ur Car over heated ever......for that you need to keep an eye on your speedometer for Temp.Guage..
    if Your temp guage exceeds normal level,it can damge the gas Kit..
    gas Kit For mehran is Very Unreliable..
    in morning... let your car start for 5 min without pressing throtle.
    if ur car is old one with cng kit installled...
    then you must Check life of your Gas cylinder.
    if its inspection date is near.. get it done as soon as possible
    thats the most important thing to do..
    masoodrazi's Avatar
    Jul 2012
    Sadiqabad
    i have mehran 2007.i have faced a problem in temp two time.first my radiator water box cap pusshed up suddenly.secondly my water pipe brust that time my fan was auto and i was in driven in local city. some month before i was clean spedo meter and temp and fuel gauge.i thought my gauges have been faulty or dislocat and thermostate may be faulty.so i want to check or calibrate of my both gauges and temerature sensor and fan thermostate.any body can help me about this problem
