These are the sensors that you will need aside from the electric air mix motor and blower resistor.
Sent from my XT925 using Tapatalk 4
These 3 are required for the auto mode to work properly.
Dear xsxd
I also installed auto climate control to my 99 civic. I installed panel which gives double din space and it has auto AC mode. I installed all three sensors i.e. inside / outside temp sesor + sunlight sensor alongwith air mix motor and blower resistor but when I switch to auto AC mode it do not turns on AC automatically rather I have to press AC button. Please help.
Dude, I wasn't there when the guy installed this... So no idea how he rewired it. If you're in karachi I can give you his reference.
If you swing by Lahore maybe shazo can point you to the right direction.
