I Guess You Need At-least 2 Tubes Per Engine But Again It Depends On Your Use And Size Of Engine...!
Not To Mention Its Not Used On Every Place.... Xulfi Bhai Can Explain in Much Details...!
1x of each will serve you many engine rebuilds
Regarding the permatex #1 and #2, I'd suggest you get their threebond equivalents.. Threebond is a much better product with a slight increase in price
Sent from my VS980 4G using Tapatalk
thank you. this is much help. yeah @xulfiqar suggested to go for threebond 1207B or AC Delco gray. i will try and find one
Adenwalla is awesome, you want a carb + throttle body cleaner get it from them, permatex! At least its not just a carb cleaner which is not appropriate for many modern cars. White lithium grease and silicone grease? they have it! It's a treasure trove of stuff there and a the prices are better and more reasonable than anywhere in Pakistan!
@capsat do they carry cavity waxes too at adenwalla?
they have huge range of sealants / resisting compounds if you call n speak to the person he can suggest the right brand & item for your need
