running away from police is never a great idea. always confront and explain your reason.
@beeberg
wats update from mechanic.
@Beeberg
Go for a 2E engine if u can afford it. Its the best option considering your situation. price should be around 30K
@imranbhatti
he is an idiot. all 5 valves are working fine only 1 is a bit leaked u can say negligible. he only saw very few white very very small spots and told it is leaked and head is crack the head wlaa in bilal gunj told just chnage its gasket and no worries. we will be returning the yeterday's purchase and will get ours back and have got gasket so today i will be on my car inshallah.
that idiot mechanic has broken 3 heaters :x
@szuberi
yesterday i was in hurry and bit tensed so couldnt answer ur questions well.
infact, car never went 70% of the indicator bar of heat.when it crossed 50% i stopped and cooled down and moved further. mechanic took out head and checked all valves of it. it contained 6 valves i think or may be i am wrong its head contained 6 cylindrical things in it. 5 were fine only one was with white very very minor spots. he showed that to me and told it is all gone.there was no white smoke. only the startup black smoke and later smoke at 5 or 6 rpm. no idle engine running smoke.he was an idiot, the head is checked from some reliable person who deals in heads of cars. he told just put new gasket and fit it back u r all done. get good janns for it.there is no downside leakage. yes i found some oily water in radiator.
@spectra
bhai i am unable to find specs of 2E on internet. well i am trying.
@master levin
i dont have license, the police wala has taken my previous learners of 12 months the new license fee and photographs along with id card copy to make new one. and since that day he is unable to reach. i know its my mistake but i feel i should get learner now and fulfil 6 months duration to complete eligibility of license. so stopping even with license means you either have to give bribe or show some reference or worse is u r locked up with car due to over speeding charges.better is to run.
its the same engine which came in 93 onwards corolla nd was there in 86 and 88 corolla as well.
ok saqib bhai thanks but poor google is unable to show specs of it. can u tell me how much hp and the cc of it.me and imranbhatti saw nissan 1.3 brand new engines never got oil in them at bilal gunj. asking price was 35k.but i will look for 2E in market too.
Thanks to Allah that you are saved thrice! (y)
Check the link for 2E:
thanks adnan bhai you always come at right time
You are welcome bro! (y)
dont do a complete swap for a new motor....just fix this one up. while you are getting a new gasket...make sure u do the following
clean up the busted gasket very thoroughly...use a scraper...make sure nothing drops inside the cylinders..use wd40 on the surface of the block and the head to bring out the shine and lubricate it...
check the condition of the head studs...the long screws that protrude from the head and go into the block...clean them and most certainly...put anti seize polish or compound on them....if i were you...ill get new head studs altogether but if budget is tight...check them and use them back.
it is also a good idea to put a new timing belt and water pump while you are at it.
good luck
i have also seen those nissan engines in pindi. same asking price. those are also excellent options.
Beeberg no License hmmz bro get one ASAP its dangerous to drive without license if khuda na khuwasta some guy dies with ur car u will be charged 302 if i m not wrong...
Look like ur mechanic is guessing alot
So it was close miss with the coppers
New gasket was purchased on 19th of nov.
note: charade with turbo and without turbo has different gaskets
New mounting (front) also purchased.
One tapid cover seal was also purchsed.
Two balance rod bush
4 other balance rod bush also purchased for full engine grip and balance.
he is scrachting out the prvious jain and applied oil later to make it more smooth.
do check the hose pipes and other cooling system essentials or u may encounter another situation with some FX having Jhang Registration
How about a race with the quantum after the head job is done to your satisfaction?
