hello!
Nissan 350Z is my favourite also...here are the specifications of 350Z
Engine
Name
VQ35DE
Cam Design
DOHC
Orientation
Longitudinal
Cylinders / Configuration
V6 w/ Continuous Variable Valve Timing Control System (CVTCS) & Molybdenum coated pistons
Block / Head Composition
Aluminum/aluminum
Displacement (liters)
3.5L
Horsepower
287 @ 6,200 RPM
Torque (lbs/ft)
274 @ 4,800 RPM
Bore & Stroke (mm)
95.5 & 81.4
Compression Ratio (:1)
10.3
Maximum Engine Speed
6,600 RPM
Induction System
Sequential multi-point electronic fuel injection
Valvetrain
4-valves-per-cylinder
Engine Cover
Standard
Engine Mounts (3 mounts per vehicle)
2 liquid filled; 1 rubber
Recommended Fuel
Premium unleaded
Emissions System
Closed loop feedback system w/ 3-way catalyst
Emission Certification Level
LEV
Exhaust
Dual (single each side)
Electrical
Ignition System
Electronic, Nissan Direct Ignition System (NDIS)
Starter
1.4KW Reduction
Alternator
110 Amp.
Battery
12 Volt
Transmission and Drive System
Drive configuration
Mid-mounted front-engine / rear wheel drive
Transmission Type 6-speed manual
5-speed auto w/ manual mode
Standard (Base, Enth, Touring 6MT, Track)
Standard (Touring 5AT) Optional (Enth)
Gear Ratio
1st
2nd
3rd
4th
5th
6th
Reverse
M/T A/T
3.794 3.540
2.324 2.264
1.624 1.472
1.271 1.000
1.000 0.834
0.794 N/A
3.446 2.370
Final Drive Ratio
3.538 3.357
Drive Shaft
Carbon Fiber Reinforced Plastic (CFRP)
Viscous-Limited Slip Differential
Standard on all models but Base
Vehicle Dynamic Control
Standard on Perf, Touring 6MT and Track models
Brakes
Standard (Standard on all except Track)
Front
Type
Vented Disc, 2 caliper pistons
Rotor size diameter and thickness (in.)
11.65" x .95"
Rear
Type
Vented Disc, single caliper piston
11.50" x .63"
Brembo (Standard on Track)
Front
Type
Vented Disc, 4 caliper pistons
12.76" x 1.18"
Rear
Type Vented Disc, 2 caliper pistons
12.68" x .87"
Brake Assist
Standard
Brake Control
Power-assisted (vacuum)
ABS
Standard
Number of Wheels
Number of Channels
Number of Sensors
Electronic Brake force Distribution (EBD)
Standard
Parking Brake
Hand operated along left side of center console
Steering
Type
Engine speed sensitive power rack-and-pinion
Power Assisted
Standard
Overall Ratio
15.9
Turns (lock to lock)
2.6
Turning Diameter (curb to curb, in feet)
35.33
Turning Diameter (wall to wall, in feet)
37.27
Steering Wheel
Tilt
Telescopic
3-spoke design w/ air bag
Manual
N/A
Suspension
Front
Independent multi-link aluminum suspension
Front Strut Tower Bar
Standard
Stabilizer Bar
Standard
Rear
Integrated Strut Tower Brace
Standard
Stabilizer Bar
Standard
Body / Chassis
Type
Unibody
Materials (primary)
Corrosion resistant and high strength steel
Hood
Aluminum
Rear Hatch
Steel
Thanxx
