@ RedBull_ar
sir jee 2 uses both 1st and second gear.... !!!
and D3 uses 1st three gears ...!!!
no ...u r wrond tht theres no pick diff in d and d3 ...!!
i did a practical last night !
i touched 100 km/hr in D3 ....Wat i noticed from RPM needle(tachometer) is tht ke at the speed 45 it changed 1st gear and at 90 it changed 2nd and obviously then it was in third gear !!
then in "D" i did the same thing ,i touched 100km/h and ven the car was at 100 its rpm needle was in b/w 2 and 3 so it means tht it was in 4 th gear !!!
Ya !! theres not a big diff b/w d and d3 ...
but in D3 u can take ur car easily upto 130- or 140 i guess but if the car is in "d" then it will shift over 2 4th gear max afta 90 or 100 so here is the pic diff !!!
4th gear mein petrol gari mar jati hai us ka pick kux nahi rehta ...!!! if compared to diesel !
bas ji bara suna tha civic ka pick corolla se bohat ziada hai dats y was doin all these things !!!
and yes it has bad affects on engine for sure so agree wid all of u tht i should betta drive it in "D"
AND ITS DAMN TRUE THT ITS pick is betta than corolla s pick !!
ALLAH HAFIZ
