This the new 2010 BMW M5 F-10.A total change in shape and performance.
The 550i is powered by BMW's stunning 4.4-liter, 400-hp twin turbocharged V-8 engine. Compared to BMW's earlier, normally aspirated V-8, displacement is reduced from 4.8 to 4.4 liters, and incorporates twin turbochargers with High Precision direct injection. In quantitative terms, the new engine delivers its 400 hp over a range from 5500 to 6400 rpm. Maximum torque is 450 lb-ft, available over the extremely broad range of 1800 to 4500 rpm. Aside from the dramatic thrust that drivers will notice subjectively, the objective data are dramatic too: 0-60 mph is estimated to be in just 5.0 seconds (preliminary) and a top speed when equipped with the Sport Package of 150 mph. For models without Sport Package the maximum speed is limited to 130 mph.
Through its unique reverse-flow layout, the 550i's V-8 engine is able to achieve higher output without correspondingly higher fuel consumption. In technical terms, the approach involves some very new design details. For the first time, twin turbochargers and the exhaust-cleansing catalytic converters are placed between the V-8's two cylinder banks. In turn, this required the exhaust camshafts and valves to be inboard so that the path from cylinders to turbochargers (which are driven by exhaust gas) would be kept short. A key benefit of this layout becomes a more compact engine package. This is the reverse of a traditional V-8 layout, and opens a new era of V-8 engine development potential.
BMW's newest gasoline inline-6 engine will be the powerplant for the new 535i Sedan. It features a single, twin-scroll turbocharger and 3.0 liters of displacement. In addition to High Precision direct injection, the new engine is the first BMW inline-6 to be equipped with both turbocharging and BMW's VALVETRONIC throttle-less intake technology. The combination of these BMW EfficientDynamics technologies delivers improved throttle response from idle to redline, reduced fuel consumption, and substantially reduced emissions. The new engine is rated at 300 hp at 5800 rpm and 300 lb-ft of torque. The torque peak is notable for its incredible accessibility: the full 300 lb-ft is available from 1200 rpm - 5000 rpm.
