Toyota issued today a recall for about 2.8 million cars worldwide, I guess in Pakistan JDM cars are effected, I have translated the target cars from toyota japan website, please check and do the needfull yourself as i dont think Indus will be interested! Not sure if the indus corolla is also effected by this - according to news, Indus should annouce this.
[TABLE="width: 0"]
<TBODY>[TR]
[TD="width: 713"][TABLE="width: 100%"]
<TBODY>[TR]
[TD="class: txt04"]13 recall of Prius models, such as the wish[/TD]
[TD="class: txt02, align: right"]Notification number 3055
on November 15 start date recall[/TD]
[/TR]
</TBODY>[/TABLE]
[IMG]http://toyota.jp/recall/image/red_line.gif[/IMG] [TABLE="width: 100%"]
<TBODY>[TR]
[TD][/TD]
[TD="class: txt02"]For part of the vehicle 13 Prius models, such as the wish, I was reported to the Ministry of Land, Infrastructure and Transport following the recall of content on November 14, 2012.[/TD]
[TD][/TD]
[/TR]
</TBODY>[/TABLE]
<TBODY>[TR]
[TD="width: 51%"][/TD]
[TD="width: 33%, align: right"]Illustration improvement place (1)[/TD]
[TD="width: 16%, align: right"]Illustration improvement places (2)[/TD]
[/TR]
</TBODY>[/TABLE]
[IMG]http://toyota.jp/recall/image/line.gif[/IMG]
<TBODY>[TR]
[TD][/TD]
[TD="class: txt02black"]One. Status of the problem
[TABLE]
<TBODY>[TR]
[TD="width: 14"](1)[/TD]
[TD="width: 667"]Because some strength side of the gear box (inter-mi extension shaft) is insufficient fitting parts in the steering apparatus, which connects the gear box and handle, and repeat the operation to cut full strong handle at low speed, backlash may occur at the junction of the fitting components. Therefore, to continue using it, there is a possibility that the connecting portion is worn, the steering operation is not possible.[/TD]
[/TR]
[TR]
[TD="colspan: 2"][/TD]
[/TR]
[TR]
[TD]Some of the hybrid system in voltage converter for electric water pump (inverter), with a wound in the coil wire for the coil winding process is inappropriate. Therefore, the output limit travel warning lamp and the water pump is stopped due to corrosion of the coil wire disconnection. Further, when the line-to-line short circuit, there is a possibility that the traveling becomes impossible off the power fuse.
Device that converts DC to AC high voltage inverter:[/TD]
[/TR]
</TBODY>[/TABLE]
2. The contents of improvement
<TBODY>[TR]
[TD="width: 10"](1)[/TD]
[TD]All vehicles, inspect, and replace it with measures from the joint parts.[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]We will replace the product measures all vehicles, the water pump.[/TD]
[/TR]
</TBODY>[/TABLE]
3. Target vehicle
<TBODY>[TR="class: txt03"]
[TD="width: 110, bgcolor: #999999"]The expression of type[/TD]
[TD="width: 140, bgcolor: #999999"]Common name[/TD]
[TD="width: 140, bgcolor: #999999"]Containing the target vehicle
chassis number[/TD]
[TD="width: 130, bgcolor: #999999"]Production period[/TD]
[TD="width: 60, bgcolor: #999999"]Of the target vehicle
number[/TD]
[TD="width: 70, bgcolor: #999999"]The corresponding
defect[/TD]
[/TR]
[TR]
[TD="class: txt02black"]NHW20 ZA-
DAA-NHW20[/TD]
[TD="class: txt02black"]Prius[/TD]
[TD="class: txt02black"]NHW20-0001043 ~
0133242 NHW20-[/TD]
[TD="class: txt02black"]August 1, 2003 -
October 13, 2004[/TD]
[TD="class: txt02black"]61,137[/TD]
[TD="class: txt02black"][TABLE="width: 100%"]
<TBODY>[TR]
[TD="class: txt02black"](1) (2)[/TD]
[TD="class: txt02black"]:[/TD]
[TD="class: txt02black"]10,476[/TD]
[/TR]
[TR]
[TD="class: txt02black"](1)[/TD]
[TD="class: txt02black"]50,661[/TD]
[/TR]
</TBODY>[/TABLE]
[/TD]
[/TR]
[TR]
[TD="class: txt02black"]NHW20-3000002 ~
3589297 NHW20-[/TD]
[TD="class: txt02black"]September 30, 2004 -
16 December 2011[/TD]
[TD="class: txt02black"]170,700[/TD]
<TBODY>[TR]
[TD="class: txt02black"]90,961[/TD]
[/TR]
[TR]
[TD="class: txt02black"]79,739[/TD]
[/TR]
</TBODY>[/TABLE]
[/TD]
[/TR]
[TR]
[TD="class: txt02black"]NHW20-7000004 ~
7091203 NHW20-[/TD]
[TD="class: txt02black"]October 6, 2004 -
May 21, 2007[/TD]
[TD="class: txt02black"]24,045[/TD]
<TBODY>[TR]
[TD="class: txt02black"]2,112[/TD]
[/TR]
[TR]
[TD="class: txt02black"]21,933[/TD]
[/TR]
</TBODY>[/TABLE]
[/TD]
[/TR]
[TR]
[TD="class: txt02black"]NHW20-7500006 ~
7894049 NHW20-[/TD]
[TD="class: txt02black"]May 8, 2006 -
March 27, 2009[/TD]
[TD="class: txt02black"]89,262[/TD]
<TBODY>[TR]
[TD="class: txt02black"]60,983[/TD]
[/TR]
[TR]
[TD="class: txt02black"]28,279[/TD]
[/TR]
</TBODY>[/TABLE]
[/TD]
[/TR]
[TR]
[TD="class: txt02black"]UA-ZNE10G
ZNE10G CBA-
DBA-ZNE10G[/TD]
[TD="class: txt02black"]Wish[/TD]
[TD="class: txt02black"]ZNE10-0001001 ~
0432646 ZNE10-[/TD]
[TD="class: txt02black"]January 8, 2003 -
March 9, 2009[/TD]
[TD="class: txt02black"]366,050[/TD]
[/TR]
[TR]
[TD="class: txt02black"]UA-ANE10G
ANE10G CBA-
DBA-ANE10G[/TD]
[TD="class: txt02black"]ANE10-0001002 ~
0034771 ANE10-[/TD]
[TD="class: txt02black"]April 17, 2003 -
March 9, 2009[/TD]
[TD="class: txt02black"]30,880[/TD]
[/TR]
[TR]
[TD="class: txt02black"]CBA-ZNM10G
CBA-ZNM10W[/TD]
[TD="class: txt02black"]Isis[/TD]
[TD="class: txt02black"]ZNM10-0001001 ~
0064635 ZNM10-[/TD]
[TD="class: txt02black"]- September 13, 2004
September 28, 2009[/TD]
[TD="class: txt02black"]59,936[/TD]
[/TR]
[TR]
[TD="class: txt02black"]ANM10G CBA-
DBA-ANM10G[/TD]
[TD="class: txt02black"]ANM10-0001001 ~
0111941 ANM10-[/TD]
[TD="class: txt02black"]33,393[/TD]
[/TR]
[TR]
[TD="class: txt02black"]TA-NZE120
NZE120 UA-
CBA-NZE120[/TD]
[TD="class: txt02black"]Corolla[/TD]
[TD="class: txt02black"]NZE120-0001004 ~
NZE120-0129741[/TD]
[TD="class: txt02black"]August 22, 2000 -
September 29, 2006[/TD]
[TD="class: txt02black"]5,777[/TD]
[/TR]
[TR]
[TD="class: txt02black"]NZE120-3000000 ~
NZE120-3126444[/TD]
September 15, 2006[/TD]
[TD="class: txt02black"]11,924[/TD]
[/TR]
[TR]
[TD="class: txt02black"]TA-NZE121
UA-NZE121
NZE121 CBA-
DBA-NZE121[/TD]
RUNX Corolla
Alex[/TD]
[TD="class: txt02black"]NZE121-0001005 ~
NZE121-0409198[/TD]
October 2, 2006[/TD]
[TD="class: txt02black"]126,225[/TD]
[/TR]
[TR]
[TD="class: txt02black"]NZE121-3000000 ~
NZE121-3398385[/TD]
[TD="class: txt02black"]136,909[/TD]
[/TR]
[TR]
[TD="class: txt02black"]NZE121-5000002 ~
NZE121-5109117[/TD]
[TD="class: txt02black"]July 2, 2001 -
[TD="class: txt02black"]82,542[/TD]
[/TR]
[TR]
[TD="class: txt02black"]UA-ZZE122
CBA-ZZE122[/TD]
[TD="class: txt02black"]ZZE122-0091394 ~
0275641 ZZE122-[/TD]
[TD="class: txt02black"]September 16, 2002 -
October 1, 2006[/TD]
[TD="class: txt02black"]7,244[/TD]
[/TR]
[TR]
[TD="class: txt02black"]ZZE122-2001107 ~
2047140 ZZE122-[/TD]
[TD="class: txt02black"]- September 16, 2002
[TD="class: txt02black"]4,880[/TD]
[/TR]
[TR]
[TD="class: txt02black"]ZZE122-3042055 ~
3196666 ZZE122-[/TD]
[TD="class: txt02black"]10,727[/TD]
[/TR]
[TR]
[TD="class: txt02black"]NZE121G TA-
UA-NZE121G
NZE121G CBA-
DBA-NZE121G[/TD]
[TD="class: txt02black"]Corolla Fielder[/TD]
[TD="class: txt02black"]NZE121-0001001 ~
NZE121-0371747[/TD]
August 5, 2005[/TD]
[TD="class: txt02black"]135,012[/TD]
[/TR]
[TR]
[TD="class: txt02black"]NZE121-3324729 ~
NZE121-3398380[/TD]
[TD="class: txt02black"]August 22, 2005 -
[TD="class: txt02black"]36,190[/TD]
[/TR]
[TR]
[TD="class: txt02black"]ZZE122G TA-
UA-ZZE122G
CBA-ZZE122G[/TD]
[TD="class: txt02black"]ZZE122-0092704 ~
0221992 ZZE122-[/TD]
August 5, 2005[/TD]
[TD="class: txt02black"]22,760[/TD]
[/TR]
[TR]
[TD="class: txt02black"]ZZE122-3144601 ~
3196668 ZZE122-[/TD]
[TD="class: txt02black"]6,940[/TD]
[/TR]
[TR]
[TD="class: txt02black"]NZE121N TA-
UA-NZE121N
CBA-NZE121N[/TD]
[TD="class: txt02black"]Corolla Spacio[/TD]
[TD="class: txt02black"]NZE121-3030289 ~
NZE121-3400913[/TD]
[TD="class: txt02black"]May 7, 2001 -
June 26, 2007[/TD]
[TD="class: txt02black"]81,728[/TD]
[/TR]
[TR]
[TD="class: txt02black"]TA-NZE127
UA-NZE127[/TD]
[TD="class: txt02black"]WiLL VS[/TD]
[TD="class: txt02black"]NZE127-0001001 ~
NZE127-0005628[/TD]
[TD="class: txt02black"]January 7, 2002 -
April 19, 2004[/TD]
[TD="class: txt02black"]3,193[/TD]
[/TR]
[TR]
[TD="class: txt02black"]ZA-ATH10W
ATH10W CAA-
DAA-ATH10W[/TD]
[TD="class: txt02black"]Alphard
Hybrid[/TD]
[TD="class: txt02black"]ATH10-0001007 ~
0025620 ATH10-[/TD]
[TD="class: txt02black"]July 11, 2003 -
March 31, 2008[/TD]
[TD="class: txt02black"]6,050[/TD]
[/TR]
[TR]
[TD="class: txt02black"]ZA-AHR10W
CAA-AHR10W[/TD]
[TD="class: txt02black"]Estima
Hybrid[/TD]
[TD="class: txt02black"]AHR10-0001055 ~
0014394 AHR10-[/TD]
[TD="class: txt02black"]- May 10, 2001
May 31, 2002[/TD]
[TD="class: txt02black"]1,684[/TD]
[/TR]
[TR]
[TD="class: txt02black"]AHR10-2000001 ~
2014001 AHR10-[/TD]
[TD="class: txt02black"]June 10, 2002 -
December 2, 2005[/TD]
[TD="class: txt02black"]2,358[/TD]
[/TR]
[TR]
[TD="class: txt02black"]ZA-GBS12
CAA-GBS12[/TD]
[TD="class: txt02black"]Crown sedan[/TD]
[TD="class: txt02black"]GBS12-0001017 ~
0003626 GBS12-[/TD]
[TD="class: txt02black"]October 4, 2002 -
April 18, 2008[/TD]
[TD="class: txt02black"]527[/TD]
[/TR]
[TR]
[TD="class: txt02black"]ZBA-HEU20W[/TD]
[TD="class: txt02black"]TOYOTA FCHV-adv[/TD]
[TD="class: txt02black"]HEU20-0001101 ~
0001125 HEU20-[/TD]
[TD="class: txt02black"]June 3, 2008 -
November 28, 2008[/TD]
[TD="class: txt02black"]25[/TD]
[/TR]
</TBODY>[/TABLE]
Note: [TABLE]
<TBODY>[TR]
[TD="class: txt02"]One.[/TD]
[TD="class: txt02"]Be included within the scope of the chassis number of the target vehicle, including the vehicle so that do not qualify, for more information please contact the nearest Toyota dealer.[/TD]
[/TR]
[TR]
[TD="class: txt02"]2.[/TD]
[TD="class: txt02"]Production period of the target vehicle is different from the time of purchase.[/TD]
[/TR]
</TBODY>[/TABLE]
[/TD]
[TD][/TD]
[/TR]
</TBODY>[/TABLE]
<TBODY>[TR]
[TD][/TD]
[TD]Us to everyone's favorite, indeed I am sorry for the inconvenience, because it will be announced from Toyota dealers, as soon as possible, the date and time you book your visit to the patronage of the nearest car dealer , I would like to ask that you receive a free inspection and repair. We apologize for the inconvenience that we have much to everyone for your love I apologize sincerely[/TD]
[/TR]
</TBODY>[/TABLE]
[/TD]
[/TR]
</TBODY>[/TABLE]
Source: toyota.jp ?A?t?^?[?T?[?r?X ?b ???R?[???????? ?b 2012?N ?b ?v???E?X?A?E?B?b?V?????@13???????R?[??
