Well As I Know....
BT Came With 0.5mm Oversized Pistons As Same As 7AFE....So I Think It Will Work For Sure.......!!
Use BT Pistons + 0.8mm TRD Gasket If You Want High CR Engine Without Head Shave
Keep In Mind That BT Have 5 Valve Shape Embedded On Pistons...So Hope This Won't Make Any Diff...And Work Fine Without Hitting Anything........!!
95% are Sure that this will work
