Page 16 of 55 FirstFirst ... 6141516171826 ... LastLast
Results 301 to 320 of 1083
Like Tree343Likes
Thread: Engine Swap in Nissan Sunny 1991 (B13)
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Default Engine Swap in Nissan Sunny 1991 (B13)
    AoA,
    Thread update: Swapped the engine with EFI one after wasting double the money on overhaul. Details of swap from page-2
    Guys I recently got a Nissan Sunny 1991. Currently it has a carby 1300cc engine, which frequently gives bluish white smoke, particularly, during start ups. Its very generous in eating up the engine oil.
    Many have suggested to go for 16 valve twin cam EFI engine. One guy told me that he visited Ahata Mithu a few months ago and got 12 valve engine swapped for 17k, while 16 valve engine was available for around 24K.
    Would appreciate if someone can guide me about best engine (I prefer EFI), the prices, the best place to get engine and best workshops to get the Nissan swaps done.
    Thanks
  2. #301
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Quote Originally Posted by star2 View Post
    You need to change the fuel pipes and proper wiring of QG before this questions! okay
    Jee Zubaida Apaa
    Keep a cool head and wear seatbelts!
  3. #302
    star2's Avatar
    Oct 2006
    31
    3,427
    6
    324 Post(s)
    9 Thread(s)
    Quote Originally Posted by spectra View Post
    No first hand experience but it should be able to do 17-18 max. The best I got is 17.2 from QG13 once but i had a cold/fever so was driving like a granny when i went to lahore and came back on same tank (41 liters)
    that average is of "khushq" engine, you getting that daisi term ?? I mean the engines which are sealed or built properly and have stock/factory settings of mixture and everything in optimum condition.
    IN A SWAP, WE DO NOT GET OPTIMIZED ENGINE
    and other accessories. So don't give him khush fehmis . Instead he needs to do a lot of work in my opinion to get this engine to even 13-14 at the moment.
    success is the ability to go from one failure to the next without any loss of enthusiasm
  4. #303
    star2's Avatar
    Oct 2006
    31
    3,427
    6
    324 Post(s)
    9 Thread(s)
    and start up by putting the original N16 air filter worth Rs. 2600.
  5. #304
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    There is no mixture setting in N16 or for that matter any EFI Swapped engine should be good in condition to get such mileage. Air filter is one aspect. Sealing of intake and piping is another. Even with Leppon filters, u can get this mileage. Just need to change early. Original ones last for 20k kms easily and leppon goes for 5k.
  6. #305
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Nissan engine requires 5 heat range plugs. 6 is usable as well but not optimum. I use Autolite compatible irridium plugs and they are just flawless. last more then 80k kms easily. Oil should be proper spec.
    I have factory manual for N16 and use it to make sure i am performing correct maintenance.
  7. #306
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    By the way I asked you to enquire about the fuel pump? Which fuel pump they have put in and how they have put it in? U inquired that ?
    Will do on my next visit.....!!!
  8. #307
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    You Have To Swap The Gauge Itself...It Can Be Fitted...SOmehow Why Don't U Leave The Fuel Gauge As OEM And Do rest Of Work..!
    Just Work On Tachometer Part And Get The Fuel Gauge Working As It Was Before
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
  9. #308
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    I forgot the most important component about economy. The O2 sensor is mostly culprit in swap engines and it can give as bad mileage as your old carb engine if it is faulty.
  10. #309
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Quote Originally Posted by SER_GTR View Post
    U mean to replace the gauge with B13 one and put a separate RPM?
  11. #310
    bilalahm's Avatar
    Jan 2004
    3,045
    23 Post(s)
    7 Thread(s)
    Paa Jee, that pic of a 74 should be considered blasphemy in this thread....... kalaijay vich thand pay gayi ? U would thrust in a 74 related thing even if a boieng is being discussed in actual :-D
    Apart from pakwheels, my blogs can be also be viewed at http://tajziat.blogspot.com/
  12. #311
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Before petrol leaked, there was around 1-1.5 L in tank when I filled Rs. 1000 (8.7L) more.
    Assuming it was a total of 10L, the reading on odo was 100Km when it leaked, and the amount that leaked seemed to be around 2L.
    So from these daysi calculations, I can expect to get 12Km/L in city without doing any rocket science
  13. #312
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Quote Originally Posted by bilalahm View Post
    O CNG walo. tumhain kiya pata
  14. #313
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Quote Originally Posted by IsbCap View Post
    Not bad for a start but an accurate calculation with tank to tank fill up will be usefull. This taxi driver technique is very misleading
  15. #314
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    With a dead gauge, and the petrol average not established, you can imagine how it feels like driving??? So I can only live with this technique at the moment
  16. #315
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Never mind, with my Multimeter in action, I can know how much petrol is in tank before leaving. The tank output wires are at the corner of the seat, and very easily accessible.
  17. #316
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    I Mean Keep The OEM Setup For Fuel Gauge As It Was In E10/E13 Engine....Have Separate Gauge Place In Fuel Tank........Not With Fuel Pump....!
  18. #317
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    The Fuel Flaot You Have Now Is Comtiable WIth B13 Meters....
    You Need To Get That RPM Type B13 Meter......EFi Type....!
    It Will Have VSS Speedo As Well As RPM Meter...Make EVerything Work 1st...CEL/Petrol/Temp And Everything Work....You Need To Wire The Damn Thing All Again.....That's One Hectic Job...I Have Done It And Know How It Feels....!
    Then Come Toward RPM In End.....If You Can Fiddle With Pulse Type And COnvert It For B13 RPM..Thats Great....Else You Need To Swap The RPM Meter With N-16 Type...For That U Need To De-Assemble Your B13 Meter And Get RPM From N-16 Type And Fit Into This....
    Just Don't Go For Whole Meter Swap As I Don't Think It Will Fit Into That Tight Dash Place And You Need To Do A Whole Lot Of Work......Possibly Some ALters Which Will Make It UGLY JOB
  19. #318
    bilalahm's Avatar
    Jan 2004
    3,045
    23 Post(s)
    7 Thread(s)
    Nissan kay thread mein bhi chohattar, yani hay had he hogayi :p Next would be spectra kay alloys right :-D
  20. #319
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Spectra ke alloys aik indus corolla wala le gaya thaa. App bas sochtay raha karain
  21. #320
    bilalahm's Avatar
    Jan 2004
    3,045
    23 Post(s)
    7 Thread(s)
    Paa Jee based on your current experience your next signature should be ......... Nissan. Keep a clean O2! :p
