WoW, Nissan left the copyrights for 3-row ECU to an illiterate ustaad in Rawalpindi, very fascinating.
Rephrasing the already available working from Bro Ghuncha:
1 Injector output #1 (Red/black)
2 Injector output #2 (Yellow/black)
3 Injector output #3 (Green/black)
4 Injector output #4 (blue/black)
5 Evap Canister Purge Volume Control Solenoid Valve (Pink)
6 Not used
7 Not used
8 ? (Blue/Brown)
9 Ignition #1 (coilpack) (Brown)
10 Ignition #2 (coilpack) (Purple)
11 Ignition #3 (coilpack) (Blue/Red)
12 Ignition #4 (coilpack) (Grey/Red)
13 Radiator fan relay output #3 (Light Green/Black)
14 Radiator fan relay output #2 (Light Green/Red)
15 ? (White/Green)
16 A/C relay (output) (Blue)
17 ? (Black/Pink)
18 ? (Yellow/Black)
19 ? (Brown/White)
20 Not used
21 ? (Brown/Blue)
22 Not used
23 Not used
24 Not used
25 Not used
26 Not used
27 Valve control solenoid output (Blue/White)
28 ? (Blue/Red)
29 ? (Green/Brown)
30 ? (Purple/White)
31 Fuel Injection Ground (Red/Black)
32 ? (Green/White)
33 Not used
34 ECU Ground (Black)
35 ECU Ground (Black)
36 Not used
37 Not used
38 EGR Solenoid (White/Purple)
39 Not used
40 Not used
41 Not used
42 ? (Black/Yellow)
43 ?(Yellow/Purple)
44 Not used
45 ? (Yellow/Red)
46 ? (Yellow/Green)
47 ? (Green/Yellow)
48 TPS Ground (Black)
49 Cam Shaft Angle Sensor (Red)
50 Crank Shaft Angle Sensor (Red)
51 ? (Red)
52 Not used
53 ? (Grey)
54 Water Temperature Sensor (Brown/Yellow)
55 ? (Blue/Yellow)
56 ? (Black)
57 TPS (Yellow)
58 Refrigerant pressure switch (Red/Blue)
59 02 Sensor (White)
60 ? (Green)
61 Not used
62 ? (White)
63 ? (Light Green)
64 Not used
65 Not used
66 Not used
67 ? (Red/White)
68 ? (Light Green/Black)
69 ? (White/Blue)
101 IACV-AAC Valve (Brown)
102 IACV-AAC Valve (Light Green)
103 IACV-AAC Valve (Pink)
104 IACV-AAC Valve (Orange)
105 ? (Black/Yellow)
106 ? (Black/Yellow)
107 Crank Shaft Angle Sensor (White)
108 Cam Shaft Angle Sensor (White)
109 Refrigerant pressure switch (Red)
110 ? (Purple/Red)
111 ? (Green/Red)
112 ? (Grey/Red)
