Page 46 of 55 FirstFirst ... 364445464748 ... LastLast
Results 901 to 920 of 1083
Like Tree343Likes
Thread: Engine Swap in Nissan Sunny 1991 (B13)
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Default Engine Swap in Nissan Sunny 1991 (B13)
    AoA,
    Thread update: Swapped the engine with EFI one after wasting double the money on overhaul. Details of swap from page-2
    Guys I recently got a Nissan Sunny 1991. Currently it has a carby 1300cc engine, which frequently gives bluish white smoke, particularly, during start ups. Its very generous in eating up the engine oil.
    Many have suggested to go for 16 valve twin cam EFI engine. One guy told me that he visited Ahata Mithu a few months ago and got 12 valve engine swapped for 17k, while 16 valve engine was available for around 24K.
    Would appreciate if someone can guide me about best engine (I prefer EFI), the prices, the best place to get engine and best workshops to get the Nissan swaps done.
    Thanks
  2. #901
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    @spectra, @SER_GTR, @star2
    I've checked the knock sensor, crank shaft, cam shaft and MAF outputs at ECM side (in accordance with recommended values in the manual).
    MAF is giving 0.8V on ECM side when at idle, it is supposed to be in between 1-1.4V.
    Camshaft output is also not in accordance with desired range. Knock and crank seem fine.
    Saqib Bhai, though crank and cam are same, the manual says we should check AC voltage for crank and DC voltage for cam. Is it really so or there's something wrong in the manual???
    Secondly, at the MAF pins, the output is fine. But at the ECM side, there's some drop.
    As per the manual, if abnormally low voltage is detected at ECM from MAF, it will enter the failsafe mode. RPM will not go beyond 2500 (which indeed seems the case here).
    And also from other internet sources, if Cam sensor is bad, fail safe mode will be activated, with ignition timing value set to whatever last value was received (which in my case is set to extremely retarded value).
  3. #902
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    i am not a bijli expert but if i was you will get MAF and Cam sensor and put them in tos ee if wiring is at fault or sensors themselves. Seems like wiring power source issue though.
    Keep a cool head and wear seatbelts!
  4. #903
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Quote Originally Posted by spectra View Post
    That's one statement that you have to quote so many times
  5. #904
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    Check All The Power Sources And Measure Voltages At Grip End...1st.
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
  6. #905
    afnan.bashir's Avatar
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Check for bad ground. Verify the VCC and GND should be 5 V. Some voltage drop is just ok but it should not be i guess more than .5 volts
    93 Accord CB7 (Sold) / 2005 CL7
  7. #906
    star2's Avatar
    Oct 2006
    31
    3,427
    6
    324 Post(s)
    9 Thread(s)
    @IsbCap
    Check for a bad wiring job from a pathan (that you were very happy with till a week back)
    success is the ability to go from one failure to the next without any loss of enthusiasm
  8. #907
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    @ isbcap
    MAF can wear out and send a weak signal back to ECU, but if you are seeing loss of voltage at MAF then trace out the loss.
    For testing pulse sensors, if the sensor is 2 wire permanent magnet type, it will generate an AC voltage signal which would be quite noisy, If its a 3 wire hall effect sensor it will generate a DC pulse of 5V and the frequency of the pulse is read as position.
    To understand it - even if you slowly rotate the engine the hall effect one will read 5V once the tone wheel triggers it, in a permanent magnet sensor (2 wire) the voltage only rises on speed of the tone wheel, the tone wheel is also broken in places to determine a special event like TDC1
  9. #908
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Quote Originally Posted by star2 View Post
    @IsbCap
    Well.... I still believe that the wiring was reasonable, being mostly uncut.
    The trouble happened when I started the car by pressing full throttle.
    Now I've been reading the manual, any bad event can lead the ECU to put the system in fail safe mode, and resetting the ECU memory should be the first step to see if some persistent fault is there. I only discovered this yesterday, and with no cel connected (and none exists in dash), I'm now devising my own ways to get the fault codes and reset the ECU (based on obd-II connection diagram).
    Once a code is persistent after the reset, only then I proceed for further process.
    Regarding wiring, whatever sensors I've checked on supposed pin numbers, those are giving fine outputs. The shortcomings, as of now, are fuel pump relay, cel, auto fan.
    @Xulfiqar,
    I'm still unable to trace those two bloody sensor (camshaft - crankshaft) . Got under the vehicle after quite some effort. But working under it isn't easy for someone not used to it...
  10. #909
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    @star2
    Driving it like a Mehran has a charm of its own . For the first time in history, I've been forced to drive under 2000 RPM all the time....
  11. #910
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    for a check light - buy an wide angle LED and print a sticker that says CHECK - stick it somewhere in the dashboard (like an empty button socket) and paste the sticker there (military style)
  12. #911
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Take diagnosis switch wires out and connect them to find codes.
    Sent from my HUAWEI G610-U20 using PW Forums mobile app
  13. #912
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Is the ELM327 bluetooth scanner any good???
    And does it work with K-line as I couldn't find it in the package description. Getting one for Rs. 1850
  14. #913
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    If it works on Nissan then worth a try.
  15. #914
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Quote Originally Posted by IsbCap View Post
    Yes it works with K Line. Khreed lo........... acha suno jo be khredo Do khreedna aik ider be send ker do
  16. #915
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Quote Originally Posted by afnan.bashir View Post
    Let me try it first. Then will let you know.
    Btw, from the turtle pace I'm working at, expect it in couple of months
  17. #916
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    was just kidding. Problem is its not available in lahore, so far i have searched it. available from peshawar or isb. these days i am into buying it.
  18. #917
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    So have you managed to connect DLC with it? and did you got three row ECU pinouts
  19. #918
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    No DLC procured yet. Pinout, I've compiled myself (most part of it. a few pins remaining).
    Lost interest in it during past 2-3 days. 1st thing on agenda is wire up the DLC (after getting one, lol)
    I'm even unable to get agilator connectors to connect at the end of my multimeter leads. Isb market is $hit.
    Starting DIYs is so hard when you are unable to get the smallest of the parts. And particularly when you ask them for a part and they just say, "what???". And then refer you to other shopkeeper, who refers you to 3rd one, who refers to 4th one and the last one in the chain refers you to the 1st one
  20. #919
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Why do you need alligators at end of multimeter? you would have to do that your self. Buy a DVM lead of Rupees 50 and solder two alligator clips. In order to check connectors of ECU the most handy thing is T shaped pin so that you do not have to pry out the wires.
  21. #920
    aliam_786's Avatar
    Nov 2008
    Sahiwal
    495
    18 Post(s)
    @IsbCap
    dont buy elm 327 useless on nissan....
    i can help you in getting codes.. pming u my number...
    Muhammad Ali Murad
