Page 48 of 55 FirstFirst ... 384647484950 ... LastLast
Results 941 to 960 of 1083
Like Tree343Likes
Thread: Engine Swap in Nissan Sunny 1991 (B13)
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Default Engine Swap in Nissan Sunny 1991 (B13)
    AoA,
    Thread update: Swapped the engine with EFI one after wasting double the money on overhaul. Details of swap from page-2
    Guys I recently got a Nissan Sunny 1991. Currently it has a carby 1300cc engine, which frequently gives bluish white smoke, particularly, during start ups. Its very generous in eating up the engine oil.
    Many have suggested to go for 16 valve twin cam EFI engine. One guy told me that he visited Ahata Mithu a few months ago and got 12 valve engine swapped for 17k, while 16 valve engine was available for around 24K.
    Would appreciate if someone can guide me about best engine (I prefer EFI), the prices, the best place to get engine and best workshops to get the Nissan swaps done.
    Thanks
  2. #941
    afnan.bashir's Avatar
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    Quote Originally Posted by IsbCap View Post
    The check engine light is permanently ON. Connecting the pin 111 with +12V doesn't result in any flashing of cel.
    Hakeem sahab you need to Ground the Service check connector to retrieve the codes.
    93 Accord CB7 (Sold) / 2005 CL7
  3. #942
    star2's Avatar
    Oct 2006
    31
    3,427
    6
    324 Post(s)
    9 Thread(s)
    @IsbCap
    I have seen your engine and following you right from the day of your swap.
    Congrats, you have ruined a once fine working motor.
    I hope you would not wish to type me further.
    Best of luck.
    success is the ability to go from one failure to the next without any loss of enthusiasm
  4. #943
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Quote Originally Posted by star2 View Post
    @IsbCap
    Best of luck.
    Itna gussa??? (You're partly right, though). Thanks for wishing the luck
  5. #944
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    OK, I'm doing it in two steps. First step is to undo the damages done by idiot roadside electricians and CNG guys. While I'm already working on wiring stuff and connected a few important pins. Plus DLC has also been connected.
    Based on my requirement to cut the injectors on gas and all four injectors should be working on petrol, the idiot electrician had joined all four injectors from ECU and then installed a transfer relay to feed the four injectors. That meant on petrol, all four injectors were running all the time
    Took me some time to analyze what that guy had done. Now I have reconnected all the four injectors to ECU and devised a temporary way to cut off injectors when on CNG by means of switches. Have to move to Lahore tomorrow, so on my way back, I'll replace the switches with relays, IA.
    Idling: Like a pin drop silence (virtually) both on petrol and CNG. Just loving it.
    @star2
    Alhamdulillah, the motor was able to withstand the torture for quite some time. Now things moving in the right direction...
  6. #945
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Great find but, don't you have an emulator installed??
    Sent from my Samsung 796cc via some chain reactions..
    https://www.facebook.com/OsamaAbbasPhotography
  7. #946
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Default Update about consumption and speed
    Went to Jhang and here are few stats (with 5 adults and a kid, plus trunk full of luggage):
    Top speed: 180 (engine was willing to go more, I wasn't )
    Avg. = 15 kpl
    Distance covered (one side): 250Km Motorway, 110Km 2 way highway with low traffic)
    Too bad, alignment/balancing wasn't up to the mark, and air filter hadn't been cleaned properly for last 6 months)
    So the engine is capable to go beyond 200 even with 5 persons on board. And can give 16+ with proper tuned setup (and maybe even 18+ with non-aggressive driving).
    (Off course the speeding was done only in short bursts and on straight patch)
  8. #947
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Avg. = 15 kpl
    possibility is above than 18+ if the AFR is properly tuned........
  9. #948
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    rubs eyes......................
    all 4 injectors pulse signal lines were joined together?
  10. #949
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    indeed you are right
  11. #950
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Well... can expect anything from local ustaads. But it's actually a story of more than 7 months ago. I have taken charge of most of wiring stuff myself since then. And stupid CNG is gone forever.
  12. #951
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    This joining all injector wires is a new level of stupidity I came to know today....
  13. #952
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    well we learn a lot more from these electrisitiooonnss....
  14. #953
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by rajaatta View Post
    like what? collosal level stupidity?
  15. #954
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    no Hi Level Jugaar's science invented by Kapochike Ustaad g
  16. #955
    soulhacked's Avatar
    Oct 2014
    7
    HI there I have Nissan sunny 89 with 1000CC carby original engine its working fine its not much powerful just keeps the car going and on CNG I feel that it cant pull the weight of the car but there is no AC in it my work is in field and in summers I need chilled AC I spent last summer sweating all day, when I thought of putting AC in existing engine people advised me that your engine will collapse ,now I am thinking of swapping engine with used EFi engine I have two options 1: 1000 EFI engine and 2 : 13000 EFI engine I only want 3 things 1: mileage 2: chilled AC 3: get rid of CNG ,I don't want to waste my whole day in CNG queues I have seen the posts and I think here are many experienced people who have done experiments and so I will be much obliged if you could guide me which engine should I go for ??
  17. #956
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Im sorry but you cannot put a 13000 cc engine in your sunny.
  18. #957
    soulhacked's Avatar
    Oct 2014
    7
    Typo error bro
  19. #958
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    hahahahahhahahaaaaaaaaaaaaaaaaaaaaaaa chaaa gayay bosssss
  20. #959
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Quote Originally Posted by soulhacked View Post
    Put a 1500cc EFI engine in it. It will be powerful as well as economical. 1000cc EFI will be a PITA, and 1300EFI will be just fine. But these are rare in market, and finding spares for them will also be difficult.
  21. #960
    Site Banned Follow
    deltabudy's Avatar
    Mar 2014
    26
    more then 90% of BLOWN HEAD GASKETS are caused due
    to leakage of water throw radiator or hose pipes .
    on board temperature gauge can not show any sign
    of water loss . with this ADD-ON we can take
    control on this situation .
