Page 54 of 55 FirstFirst ... 44452535455 LastLast
Results 1,061 to 1,080 of 1083
Like Tree343Likes
Thread: Engine Swap in Nissan Sunny 1991 (B13)
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Default Engine Swap in Nissan Sunny 1991 (B13)
    AoA,
    Thread update: Swapped the engine with EFI one after wasting double the money on overhaul. Details of swap from page-2
    Guys I recently got a Nissan Sunny 1991. Currently it has a carby 1300cc engine, which frequently gives bluish white smoke, particularly, during start ups. Its very generous in eating up the engine oil.
    Many have suggested to go for 16 valve twin cam EFI engine. One guy told me that he visited Ahata Mithu a few months ago and got 12 valve engine swapped for 17k, while 16 valve engine was available for around 24K.
    Would appreciate if someone can guide me about best engine (I prefer EFI), the prices, the best place to get engine and best workshops to get the Nissan swaps done.
    Thanks
  2. #1061
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Quote Originally Posted by spectra View Post
    Know this be experience. No data available. You have to wire the 5 wire AFM properly
    Sent from my STH100-1 using PW Forums mobile app
    Yes, but from your experience, which ECU pin I should connect the 5th MAF wire?
  3. #1062
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Here I cannot help you. Maybe @star2 has the answer.
    Keep a cool head and wear seatbelts!
  4. #1063
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Lol, he chose 4 row ECU to avoid these things. I have decoded the pinout by matching it with Almera FSM. Doing R&D for this specific pin these days. Everything else sorted out.
    Love to see the non rotating fans for 99% of time
  5. #1064
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    Quote Originally Posted by dani_kk View Post
    Got your point bro, apologies.
    Sent from my SM-G360H using PW Forums mobile app
    Go
    Good To Hear You Got My Point...Didn't Mean To Offend Or Degrade Anyone Here...!
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
  6. #1065
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    Quote Originally Posted by IsbCap View Post
    I was having the problem with IACV. When connected and engine started in the morning, it shoots up the RPM to 1500 and doesn't come back till I turn off the engine. Also the STFT values were cycling from 0% to -25% all the idling time, with no LTFT set.
    Today disconnected the IACV and observed again. Values are:
    STFT: -19% to -23%
    LTFT: -10%
    Idle RPM: Fluctuates between 775-850
    From some study, it seems a rich running system. O2 seems fine, so the problem is narrowed down to:
    1. Replace the air filter
    2. Inspect the injectors for leaking or wide open
    Btw, its rich, but still done 390Km in around 26-27L of petrol (city-highway mix)
    Either IACV Is Not Working As It Shld ..Due To Incorrect Wiriring Or Other Codes...
    LTFT Are Out Also....Shld Be Near Around 0-5(+/-) But -10 Means Its On Rich Side...Need To Inspect The Cause ... It Can Be Your MAF..How Are Your Plugs Coming Out...Too Much Blackish? Or Just A Bit?
  7. #1066
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Quote Originally Posted by SER_GTR View Post
    Last time I inspected them (around 3-4 months ago), those were brown. Now the exhaust is turned black afterwards, so definitely running a bit rich.
    I'm suspecting a bad air filter (which is three years, 21000Km old, btw . While getting it cleaned last time from engine oils +filters shop, I asked the guy whether i should change it or not. Looking at the condition, he suggested it to be OK)
    No IACV related codes are there (and even disconnecting it didn't bring any codes). Wiring is fine and it had been working good previously.
    I'll be looking to clean the MAF and replace the air filter. And of course, will check the injectors by using multi meter.
  8. #1067
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    Look for Any Air Leaks Also...They Make STFT LTFt Go Crazy W.o Even Knowing..ANy Leak In Manifold Or Hose Will Result In Such Also
  9. #1068
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Seems the bloody MAF was wrongly reporting the air values (around 3.5 g/sec). I disconnected and reconnected again while engine running. And now it started reporting 2.3 g /sec. RPM became stable. Also cleaned TPS terminals.
    Went to Mangla dam and got avg. of 16.3 kpl (with 5 persons on board)
  10. #1069
    saanni_79's Avatar
    Sep 2015
    Faisalabad
    37
    38
    Unhappy
    mine QG15 is giving only 10~11kpl inside city......Idle RPMs are 1150~1200...........
  11. #1070
    ahmed2396's Avatar
    Dec 2011
    36
    2,324
    5
    55 Post(s)
    7
    Quote Originally Posted by saanni_79 View Post
    idle rpm 1200? is water temp sender working? check iacv also.
    Your ego is writing cheques, your body can't cash.
  12. #1071
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    I went to PWD yesterday, there were traffic blocks, so average was around 12.5. On the way back, not many jams, so avg. was 15.5
    On cold start in the morning and 4Km run, i get 8.5-9kpl.
    So overall, 10-11kpl in the city driving is fine.
    Regarding RPMs, those need fixing (Should be around 1000 on cold, 700 when warmed up). Giving problems now or right from engine swap?
    Check IACV and MAF as a first step. Then air filter, throttle body, TPS
  13. #1072
    saanni_79's Avatar
    Sep 2015
    Faisalabad
    37
    38
    After some adjustments , please see below screenshots ....Engine Swap in Nissan Sunny 1991 B13 -1726150Engine Swap in Nissan Sunny 1991 B13 -1726151Engine Swap in Nissan Sunny 1991 B13 -1726152Engine Swap in Nissan Sunny 1991 B13 -1726153Engine Swap in Nissan Sunny 1991 B13 -1726154Engine Swap in Nissan Sunny 1991 B13 -1726155Engine Swap in Nissan Sunny 1991 B13 -1726156Engine Swap in Nissan Sunny 1991 B13 -1726157
  14. #1073
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Idle RPM is little high. Not to worry too much, i think. Try doing the Idle Volume Learn function in NDS2 (Mine always says failed after few minutes of processing...)
  15. #1074
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Never try to clean the terminals with WD40. I did it and O2 and its wiring got short . And another bad thing, ignition switch terminal melted due to this short circuit, but the ignition fuses remained intact happily .
    Alhamdulillah, the ECU survived it. Now O2 is disconnected. And i know it is running very rich at the moment.
    Before installing new O2, I'll also need to inspect the O2 wires leading to ECU for any short circuit as well.
  16. #1075
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    520
    14 Post(s)
    Mine too
    Sent from my Z12 using Tapatalk
  17. #1076
    ahmed2396's Avatar
    Dec 2011
    36
    2,324
    5
    55 Post(s)
    7
    What can be the cause of car dropping rpm on braking in B14 GA15DE? @SER_GTR
  18. #1077
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    Quote Originally Posted by ahmed2396 View Post
    a
    Have U inspected ISCV for being stuck? or not working.... also a leak in vacuum can make rpm unstable...
    also inspect throttle blades and make sure they move freely inside and not having gunk inside...
  19. #1078
    ahmed2396's Avatar
    Dec 2011
    36
    2,324
    5
    55 Post(s)
    7
    a
    throttle was serviced completely and iacv was also cleaned. It also seems car lost some of brake boost too.
  20. #1079
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    Can Be A Leaking Brake Booster Diaphragm ...It Only Happen when you Press Brake Pedal??? Rest Its All Good? Then Check For Brake Booster
  21. #1080
    ahmed2396's Avatar
    Dec 2011
    36
    2,324
    5
    55 Post(s)
    7
    brake is not good as it was before. can you give me wear limit of front rotors of B14.
