Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 158
Like Tree33Likes
Thread: Nissan Sunny '97 - QG18DE Swap
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    Default Nissan Sunny '97 - QG18DE Swap
    Guys,
    My first experience with an engine swap; got it done in RWP Saddar with a QG18DE (bought from Mushtaq bh).
    The wiring was complete harness to harness and the ECU that came with the engine was ZZ.
    Issues:
    1. Required : OBD-II dash wiring harness as the one already installed is OBD-I and Consult-II wont thus connect to it. Looked all over but cant find the OBD-II wiring harness.
    2. RPM meter not working, the electrician (Ameer, disciple of Malang Ustaad says that a kit is required to be installed as the RPM gets its signal from the ECU).
    3. Auto choke doesnt work (esp on cold mornings when i have to warm the engine up my keeping the pedal pressed).
    4. Black smoke last week but fixed after my last visit to Ameer (after changing the throttle body, coolant temp sensor, Air flow sensor and throttle position sensor).
    5. Faqeer ustaad thinks that the ECU is a mismatch (tried 4 different ECUs but none worked other than the ZZ).
    6. Car's mileage (petrol) is around 10 km/l.
    Any suggestions/way forwards with the above 1,2,3,5 and 6 points ?
    Thanks.
  2. #61
    star2's Avatar
    Oct 2006
    31
    3,427
    6
    324 Post(s)
    9 Thread(s)
    Quote Originally Posted by spectra View Post
    link is dead.....
    success is the ability to go from one failure to the next without any loss of enthusiasm
  3. #62
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    @spectra, yeah he handed me like 2-3 ECUs as well, whichever works. Dad just talked to him and he has assured that he will find it. I have also told Ameer to look for it - he is kinda grateful to me for handing him over the wiring printouts of QG18DE
  4. #63
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    Hopefully it will be an easy find ... Anyone aware of other compatible ECU with this motor ? Better to have options
  5. #64
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    @SER_GTR Mushtaq says that his dukaan boys unplugged the ECUs and stacked them here and there... So its basically a hit and trial. Part # search would be a lot easier if somehow I knew that to which car this motor originally belonged. Anyway to know ? Right now looking for @spectra's suggested ECU
  6. #65
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    You Can Ask Fellow Pw's Member Like Phajee Told You ECU No...Look For It And You Are Good To GO
    TOYOTA's ECU's Are Easiest To HUNT And Identify...I Hate NISSAN And HONDA For ECU MESS
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
  7. #66
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    With your level of expertise you should go for a QR of MR20. Theya re cheap because noone wants to swap padle sensor aur chor switch chabi wala engine
    Saqib Bhai...Hazaaron Khwaishein Aise Jispe DAM Nikle
    Those Are Big Motors And Need To Be Handled And Swap With So Much Bijlli Work Done The Pedal Wala Sensor And Chor Chabi Wala Switch Should Give Most Of People A Run Of Their LIFE Because Of Complications Involved...
  8. #67
    star2's Avatar
    Oct 2006
    31
    3,427
    6
    324 Post(s)
    9 Thread(s)
    Quote Originally Posted by SER_GTR View Post
    who says that it is difficult
  9. #68
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Quote Originally Posted by sarmadz View Post
    How stupid it is for a shopkeeper in business to tell this thing. The controllers (ECU's) detached from engine and he doesn't even know which ECU is for which engine. And doing business for years.
  10. #69
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    Atleast he was honest , quite rare these days
  11. #70
    star2's Avatar
    Oct 2006
    31
    3,427
    6
    324 Post(s)
    9 Thread(s)
    Quote Originally Posted by IsbCap View Post
    Why would he be held accountable, the buyer should be held accountable for making the decision. Why would you buy hassle in the first place? Demand from the seller that you need engine from which the original wiring is not detached. Examine the engine properly, check the wiring, ask gaurantee, count things like sensors, look for vacuum pipes, examine the condition of block, see for dents, see for missed accessories, and then purchase the engine. You cannnot just simply blame the seller. Its always the buyer in my humble opinion.
    And you are paying for his honesty now, what you say about that ?
  12. #71
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    I was ignorant
  13. #72
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Mushtaq has to provide compatible ecu in same money. simple.
    Keep a cool head and wear seatbelts!
  14. #73
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    Consider it done Brother had every thing for it . from Diagram's to the detailed pin out each and every thing available.
  15. #74
    star2's Avatar
    Oct 2006
    31
    3,427
    6
    324 Post(s)
    9 Thread(s)
    yes right.
    I am just talking about self vigilence. Not saying anything to Mushtaq. In my opinion, and as @SER_GTR always say, we should do home work before a swap.
  16. #75
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    Quote Originally Posted by star2 View Post
    yes right.
    You are both not Normal people. You guys are geeks. Not everyone is like that and should not be assumed like that while giving forum advice.
    Sent from my HUAWEI G610-U20 using PW Forums mobile app
  17. #76
    atta1111's Avatar
    Sep 2008
    Rawalpindi
    26
    675
    52 Post(s)
    2 Thread(s)
    Bullet from my gun will suit you dear you know welllllllll
  18. #77
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    No One Says.....I Just Say Complicated.....!!
    But Surely Will Hunt Your Time......Simply A Person Like Just Can't Afford It Now....! But If I Have A Fine Work Place And Parking...I Won't Mind Working On Weekends....
  19. #78
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    ECU not found
  20. #79
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    It will be found. they are now trying to make up your mind so u spend extra for it.
  21. #80
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    Yeah I guess. They are saying that it will have to be brought in from Peshawar
