Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 81 to 100 of 158
Like Tree33Likes
Thread: Nissan Sunny '97 - QG18DE Swap
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    Default Nissan Sunny '97 - QG18DE Swap
    Guys,
    My first experience with an engine swap; got it done in RWP Saddar with a QG18DE (bought from Mushtaq bh).
    The wiring was complete harness to harness and the ECU that came with the engine was ZZ.
    Issues:
    1. Required : OBD-II dash wiring harness as the one already installed is OBD-I and Consult-II wont thus connect to it. Looked all over but cant find the OBD-II wiring harness.
    2. RPM meter not working, the electrician (Ameer, disciple of Malang Ustaad says that a kit is required to be installed as the RPM gets its signal from the ECU).
    3. Auto choke doesnt work (esp on cold mornings when i have to warm the engine up my keeping the pedal pressed).
    4. Black smoke last week but fixed after my last visit to Ameer (after changing the throttle body, coolant temp sensor, Air flow sensor and throttle position sensor).
    5. Faqeer ustaad thinks that the ECU is a mismatch (tried 4 different ECUs but none worked other than the ZZ).
    6. Car's mileage (petrol) is around 10 km/l.
    Any suggestions/way forwards with the above 1,2,3,5 and 6 points ?
    Thanks.
  2. #81
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    @star2 @spectra @SER_GTR Guys, The ECU I have is A56-Q92, after some hectic research it seems that this one belongs to a Nissan AD QG13DE. Can you all please check the catalogs ? And if this one will work on a QG18DE ?
  3. #82
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    Quote Originally Posted by sarmadz View Post
    If there's one Nissan vehicle for which you get absolutely no information from internet, it is Nissan AD/Wingroad.
    Best of luck for your ECU hunt.
    Btw, have you checked the pinout of your existing ECU?
  4. #83
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    Exactly and whatever there is, its in Russian language.
    But, QG13DE came only in :
  5. #84
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
  6. #85
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    QG13DE has no n-vct and thus this ECU wont work. Can anyone confirm @star2 @spectra @SER_GTR ?
  7. #86
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    This is a QG13 ECU and the only way to make it work with QG 18 is without NVTC and O2. But that will only make it run, thats it.
    Keep a cool head and wear seatbelts!
  8. #87
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    It May Start Vehicle But I Won't Suggest Running It.........The MAP Of Qg13 And QG18 Will Be Hell Of Different + NVTC ....It Will Be Useless And Will Make Run Quiet LEAN.......
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
  9. #88
    star2's Avatar
    Oct 2006
    31
    3,427
    6
    324 Post(s)
    9 Thread(s)
    Quote Originally Posted by SER_GTR View Post
    yeh LEAN kia hota hey
    success is the ability to go from one failure to the next without any loss of enthusiasm
  10. #89
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    Quote Originally Posted by star2 View Post
    GOOGLE Is Your Friend......!!
  11. #90
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    Found 3 QG18DE ECUs , courtesy Mushtaq Sb. MEC11-516, MEC11-506, MEC11-156. Pics latet
  12. #91
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    DLC3 found as well
  13. #92
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    Alright, I guess we are 90 % done with the whole thing. Mr. Atta most graciously offered his services on Saturday to rectify the wiring and get the ECU hooked up to the scanner.
    Turns out that there were no damn EFI relays installed :s! and Ameer Sb had totally messed up the internal wiring
    Two codes came up: P0110 and one for the O2 sensor (which shows a straight lined graph on idle and goes all sine upon accelerating 1k RPM plus).
    The MAF sensor is 3 wired so I need to get it replaced with a 4-wired one as the ECU expects the temp input (which is not present and is coming out to be -44 on the scanner).
    The MEC11-XY ECU was that of Nissan Tino 2008 QG18DE.
    Next job is to get the required MAF and O2 sensors and plug the ECU into a Consult-II.
    Special Thanks to Mr. Atta , took 14 HRS on Saturday but was totally worth it .
    Engine's all smooth revving like crazy ... Will post the video and other pics
  14. #93
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    Nissan Sunny 97  QG18DE Swap -1337082Nissan Sunny 97  QG18DE Swap -1337083Nissan Sunny 97  QG18DE Swap -1337084
  15. #94
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    And the RPM meter started working as soon as it got the signal from the ECU... No kit/circuitry required.
  16. #95
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    Good To See Your Issue Is Rectified...!!!
  17. #96
    SER_GTR's Avatar
    Nov 2005
    30
    9,735
    16
    488 Post(s)
    19 Thread(s)
    EFI Relay Belongs Actually In Engine Bay.....WIth 15A Fuse Inline
  18. #97
    star2's Avatar
    Oct 2006
    31
    3,427
    6
    324 Post(s)
    9 Thread(s)
    It usually is wired up immediately beside the ECU grip in Nissans GAs and QGs. It comes wired up with ECU, though for some stupid reasons, they chop off the relay thinking that it is just another relay they can sell for Rs. 50 and f-up the ECU wiring loom.
  19. #98
    star2's Avatar
    Oct 2006
    31
    3,427
    6
    324 Post(s)
    9 Thread(s)
    @sarmadz
    Good going. Now you know why you are getting 10 km/liter.
  20. #99
    sarmadz's Avatar
    Aug 2007
    33
    64
    15 Post(s)
    @SER_GTR the relays weren't even in the engine bay ... @star2 bro what's the milage you are getting out of your motor?
  21. #100
    star2's Avatar
    Oct 2006
    31
    3,427
    6
    324 Post(s)
    9 Thread(s)
    have'not calculated it yet, car still in progress --- paint job going on...
