Results 1 to 7 of 7
Thread: Nissan ad 2006 problem urgent response????
    humza1's Avatar
    Sep 2009
    218
    Default Nissan ad 2006 problem urgent response????
    Aoa
    Pls help me with check engine light. It has no fix time it appears on/off it lacks the power and i have to turn my car off for few minutes for meanwhile it disappears where as sometime od light start turning on and off have done my best but issue is still there.
    Pls help me guys
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Ok in lahore where are you? And what is the engine type in your ad is it hr15?
    humza1's Avatar
    Sep 2009
    218
    First of all thanks for your response
    I am in lahore gulberg and its1300cc
    humza1's Avatar
    Sep 2009
    218
    Plus pls figure out Nissan"s dealership In lahore
    rajaatta's Avatar
    Apr 2014
    682
    12
    25 Post(s)
    Ok i am on it
    muradi's Avatar
    Aug 2012
    7,199
    16
    461 Post(s)
    7 Thread(s)
    get it scanned, the plugs might be the culprit. Faced same issue on Vitz, the reason was the plugs were too tight causing failure
    Laws r Made to be Broken
    humza1's Avatar
    Sep 2009
    218
    Quote Originally Posted by rajaatta View Post
    Ok i am on it
    means????
