Results 1 to 5 of 5
Thread: NIssan Tiida A/C Problem
    morff14's Avatar
    May 2009
    Rawalpindi
    31
    114
    Default NIssan Tiida A/C Problem
    Salam,
    So my Nissan Tiida's A/C is giving the following problems:
    Upon cold start, it works fine for about 15 20 minutes ( or more if I keep driving at a high speed without stopping). But as soon as I slow down due to a traffic jam or at a traffic signal, it stops throwing out cold air (as if the compressor stopped working). Then I have to switch off the car (ignition off) and then back on for the AC to kick back in. Only turning the AC off and back on does not help. But soon, the AC trips out again. and I have to follow the same drill again. This usually continues untill I'm out of the traffic jam and have picked up some speed.
    So basically, the AC trips and does not come back - occasionally.
    It may appear obvious that is has to do with slow speed ( low compressor RPM) but I don't think so. When it's working alright, it's freezing cold even at idle. Gas pressure is good.
    Any ideas what might be causing this? Looks to me like an electric issue.
    Thanks,
    morff14's Avatar
    May 2009
    Rawalpindi
    31
    114
    Bump..
    dayrider's Avatar
    Mar 2006
    27
    1,907
    5
    16 Post(s)
    2 Thread(s)
    did you solve it?
    FBB
    FBB is offline
    FBB's Avatar
    Sep 2015
    Peshawar
    39
    520
    14 Post(s)
    Chane the relay and the check
    Sent from my QMobile i12 using Tapatalk
    morff14's Avatar
    May 2009
    Rawalpindi
    31
    114
    Quote Originally Posted by dayrider View Post
    did you solve it?
    It was an electrical issue. The switch that controls the "trip" mechanism had rust in it. So after tripping, it would not pass current. Cleaning the switch with warm water and then using WD-40 spray fixed it for me.
