Results 1 to 3 of 3
Thread: Nissan Pino CAT and high HC emissions
    farhan3d's Avatar
    May 2013
    7
    Default Nissan Pino CAT and high HC emissions
    Hey all,
    I have a 2007 Pino, and am getting concerned about high HC emissions which I found out from one of the ENERCON test centers in G-10. I guess it was around 480-490. Two months ago I had my CAT cleaned and half removed because it was choked, and car performance was great for some time. But now it's choked again, the acceleration and power is pathetic, and there is high HC emission.
    What do you suggest? As a first step I am going to get a new set of iridium plugs, although previous ones were also iridium and lasted only 1 year. Is the CAT dead? Or is there something wrong with sensor/engine/valve? Guy at ENERCON comupter testing said that the tappets were "too tight", but he just said that by looking at computer results.
    Your expert suggestions are welcome please. First preference would be to not remove the CAT.
    Many thanks!
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    half cat removed?
    farhan3d's Avatar
    May 2013
    7
    Yes, the mechanic said that it was more choked on one side so he cut it open and sawed off about less than half of cat inner material.
Tags for this Thread
